Opinions please !!!!
Old Sep 2, 2007 | 08:43 PM
duddin10's Avatar
Opinions please ...gauges or commander??
Which is better as far as looks and performance..gauges with triple pillar pod or commander with pod? I am torn between the 2. The gauges are a little cheaper but I want something I can rely on and that looks good too. What do you think?
Old Sep 2, 2007 | 09:01 PM
CoolumConst's Avatar
I am very happy with the recon, small and out of the way but still easy to read. I have not seen the commander up close to compare the two.
Old Sep 2, 2007 | 09:08 PM
dodgemaniac's Avatar
i like the gueage look better myself
Old Sep 2, 2007 | 09:13 PM
skynyrd's Avatar
i second the gauge look!
Old Sep 2, 2007 | 09:14 PM
duddin10's Avatar
Another question? Is $290 shipped to me a good price for a triple pillar pod , autometer pyro, tranny and boost gauge?
Old Sep 2, 2007 | 09:17 PM
rustyshakelford's Avatar
thats not to bad. i think i paid around that for my isspro, but i think i also got the hot line w/ port for the tranny temp
brett
Old Sep 2, 2007 | 09:27 PM
cbrahs's Avatar
xlr8r has a nice billet aluminum piece that bolts to the original A pillar and allows you to have 3 gauges AND keep the handle! that is the route I am going with.
Old Sep 2, 2007 | 09:30 PM
TNLoneWolf's Avatar
I just changed over to gauges myself.....easier to see in a glance....IMO.
The price you paid for your triple set soiunds about right, but you should be certain what parts and fittings your getting for the money. I found DieselManor after buying my set and I believe their kits are already wired for the gauge lights whereas the AutoMeter set I bought was not. I had to keep going out after silly little small parts, to me it's worth a little more up front to keep from running out after missing parts over and over again....I hope that helps.
Old Sep 2, 2007 | 09:34 PM
duddin10's Avatar
brett
They say it comes with all the wires , probes and hardware necessary to install them.
Old Sep 2, 2007 | 11:13 PM
soulezoo's Avatar
DTR 1st Sergeant
That is a good price. Is the boost mechanical or electric? big difference.
On average, depending on the autometer gauge you buy (some gauges are naturally more than others) Pyro= $135; Boost (mechanical)= $69; Tranny =$140; Triple pillar pod= $49. Again... that is an average retail separately.
Old Sep 2, 2007 | 11:15 PM
Luvnacumns's Avatar
That's a good price for autometer's... I like the analog guages myself!!
Old Sep 3, 2007 | 12:13 AM
SlowSixSpeed's Avatar
Autometer's simply look bad....They look very intimanating to other diesels.
There's a reason why NASCAR and many other racers use autometer or other analoge gauges.
There way easier to keep an eye on then a small LCD screen that displays 4 things and doesnt have a dial.
Old Sep 3, 2007 | 12:38 AM
Luvnacumns's Avatar
I like the blue!!!! I have the green ones...
Old Sep 3, 2007 | 04:17 AM
jwb600's Avatar
I have 4 dipricol gauges, 3 on the pillar and one on the column. they have always worked good for me. I would buy them again for sure
Old Sep 3, 2007 | 08:23 AM
jrussell's Avatar
The great thing about digital is you get a maximum peak recall capability. No need to try and stare at the gauge to see max values...which you usually don't end up seeing correctly with analog anyway.
Another thing is that "analog" pyros are not really analog since they use a digital source to calculate values. The digital signal is then converted to an analog display. That just makes the gauges slower to respond and increases the chance of error.
