only me
Old Mar 23, 2007 | 09:23 AM
roc155's Avatar
only me
i just have stupid luck. i pull into work and put the truck in "N" to allow the turbo to cool as i look at my gauge i'm sitting at about 650. i think what the ---- is wrong now because it just stays there and won't go down. mind you the triple dog is on the lowest setting and never even been higher than that. i finally just turn it off. after a couple of hours i went back and started the truck again now the gauge reads all the way at the bottom between 1600 and 0. when i drive off though it cools to 1200. so i think i'm the only person that has egt's get lower on my counter clock wise opereating gauge, the harder i drive the truck.
Old Mar 23, 2007 | 09:28 AM
dodgezilla04's Avatar
i had a dipricol pyro act nuts, it would get stuck around 500*. i called them and they mailed me a replacement right away.
Old Mar 23, 2007 | 09:36 AM
CrashCade's Avatar
Check your probe. It might be cracked, and need to be replaced.
Old Mar 23, 2007 | 09:39 AM
PEAKSTRYDE's Avatar
Could be the gauge or probe!!!!
Chances are you will not be able to tell if it is the probe, many times it shows nothing but reads wrong!!!!!!!!!!!!!!!
admin
Site News
26
Aug 22, 2003 02:33 PM
Stamey
18
Mar 29, 2003 10:38 PM
RHC
Feb 12, 2003 11:50 PM
Jan 7, 2003 04:24 PM
Vaughn MacKenzie
Nov 3, 2002 07:22 AM
