Ok now what
There are lost of turbos available for your truck, and Diesel Dynamics has injectors available for the 600 as well. Call Piers Diesel in BC, they have a few turbo options, and can get the Diesel Dynamics injectors as well. Looks like you are off to a pretty good start though!
http://www.piersdiesel.com/
You will need to upgrade your fuel pump on the low pressure side of the fuel system if you want to keep adding power. The lift pump can't seem to supply enough fuel when you get past 60-70 extra HP. With the EZ I was able to draw the Fuel Pressure down to 0 psi on WOT runs. I added a Diesel Dynamics pusher pump (which eliminated the stock lift pump) and now have no problems. There are others available too ie. FASS, Air Dog and Scotty I think has a system as well.
moparmatt
May 1, 2015 08:49 AM
