oil analysis info
I hope Im doing this right but I got some info If any one wants hopefully this works
KMBT20020070702155127.pdf hopefully I did this right if not let me know how
It seemed to work when I looked hope it helps somebody been charting mine for past two oil changes trying to see how long I can go between oil changes and hopefully catch a problem before it gets way out of hand
I am a little skeptical of "oil analysis". Several years ago I had a customers vehicle towed to my shop with a locked up engine. Seems that someone had filled the crankcase with water and then it was driven til it locked down. Just out of curiosity I pulled a sample and sent it in for analysis. Everything came back within acceptable levels with the recomendation to do another analysis at the next service intervel. When I called the "lab" and told them the situation, they seemed a little embarrassed. I hope your lab does a better job for you.
ctd4stan
May 5, 2011 10:39 PM
92smokin blacky
Jan 25, 2011 11:36 PM
Bobcat698
Nov 1, 2005 07:05 PM
