Off road lights
Old Apr 20, 2007 | 10:59 PM
dogcamo's Avatar
Off road lights
I'm looking for some input on some good quality off road lights, that will fit into a Westin Ultimate Bull Bar. Any input would be welcomed. Thanks
Old Apr 20, 2007 | 11:05 PM
tbarbee1's Avatar
Go to Napa try the airplane landing lights phillips and wagner both make them they arent the enourmas PIIA or KC but they put out a sealed beam that when you turn it off its like you dont have your stockheadlights on THeyre $12.00 and the rubber gromet to fit them will run about $10.00 you cant beat them for the price I have had them on the last 3 trucks Ive owned I hope this helps probably not the way you want to go if you are not into simplicity
Old Apr 20, 2007 | 11:26 PM
dogcamo's Avatar
Thanks, I'm all about simple and the price sounds great.
Old Apr 20, 2007 | 11:40 PM
annabelle's Avatar
Airplane lights are good. Go cheap, I always end up with them smashed.
Old Apr 20, 2007 | 11:48 PM
tbarbee1's Avatar
Sure they fit in the same gromet as a tractor flood light, cheap and ultra bright
Old Apr 20, 2007 | 11:50 PM
annabelle's Avatar
Aircraft landing lights.
Old Apr 20, 2007 | 11:54 PM
tbarbee1's Avatar
Yep aircraft landing lights
Old Apr 20, 2007 | 11:57 PM
annabelle's Avatar
I'm sorry, I just meant to tell him which lights, so he new what we were talking about. But I haven't tried the tractor grommets so thanks for the info.
Old Apr 21, 2007 | 12:06 AM
tbarbee1's Avatar
Annabelle have you tried these if so can you verify the part#?
Old Apr 21, 2007 | 12:11 AM
annabelle's Avatar
I never have used a parts #. But I can check on it tomarrow. Yes I have used them on many a truck. Modded them with long wire harness to use when changing flats or just working in the boonies also.
Old Apr 21, 2007 | 03:47 PM
dogcamo's Avatar
Tarbee1 I went to our local Napa looking for the lights and they looked at me like I had 2 heads. Do you have a part #?
Old Apr 21, 2007 | 05:59 PM
Desert Dually's Avatar
Man, that kind of thing happens to me a little too often as well !
Old Apr 21, 2007 | 08:09 PM
tbarbee1's Avatar
Hey man mine are Wagoner 13V part#4609
Old Apr 21, 2007 | 09:34 PM
coobie's Avatar
I have PIAA.s with the aluminum houseing installed on my 2004.Not a lick of trouble and no rust on them.PiAA,s are a little pricey but well worth it IMHO.coobie
Old Apr 21, 2007 | 11:24 PM
jdh's Avatar
jdh
I have this same Bull bar and I have the KC Slimlight. Excellent fit and a very good light. Simple install and wiring.
