no timing vs. timing
From what I understand timing allows for more efficient use of the fuel (at the cost of emissions) so there is an increase in MPG. Also the timing lowers EGTs because more energy is released in the combustion chamber instead of the exhaust. This causes high piston temps but lower EGTs to the turbo.
Overall timing would product more power for a given boost....I think.
Timing does exactly that, more heat used in the power stroke and less heat to the turbo, more efficient use of fuel for a given RPM/boost level which means higher potential MPG gain, excessive timing will destroy pistons though!!
No timing requires more fuel too burn, and results in higher egt's, lower piston temps, and potential of a loss of MPG.
The timing vs. No timing option of the smarty is too make a more widely stackable programmer, meaning if you wanna stack it with a module that adds timing....it is possible, rather than limiting your options for a stack like most other programmers do!
Thanks , I just installed my smarty last night and was not sure what the differance was.
Lovin the power increase on sw5 but am concerned about the tranny.
Ramtd02, I hope that you did not just start to mod your truck just to pull your 5er, (this is my excuse ) It just seems to have gotten away from you.
You are making some nice power.
Thanks again
Paul
Thanks again
Paul
