no go!!!
Old Feb 1, 2008 | 11:05 PM
Floridacracker's Avatar
Angry no go!!!
ok it does go, but not as fast as before
i went to the drag strip a couple mouths ago and ran a 9.4 in the 1/8th
i went tonight and ran a 10.8 and i parked the truck
well what i noticed is my egts won't go over 1,300*
they used to jump right up to 1600*
what can be the problem please help!!!
ps. i lost to a hemi
Old Feb 1, 2008 | 11:14 PM
abc4yew's Avatar
Before you were stupid and now you are lucky...that is the difference....one two many times over 1500 and your pistons will get nice and rounded along the edges and then the rings come out the exhaust valve...and I know....get some supporting mods and keep the temps in check....on an 04.5 you should be less than 1450 if you are running efficiently. KS
Old Feb 1, 2008 | 11:17 PM
i don't run it that hot very long
Old Feb 1, 2008 | 11:49 PM
Strjock81's Avatar
It isn't hard to get to 1600 with a quad race box....Wonder what the deal is? Not that you WANT it that hot.....
Old Feb 2, 2008 | 12:43 AM
Speed Shift's Avatar
What was your fuel pressure?
Old Feb 2, 2008 | 07:06 AM
MikeyB's Avatar
When was the last time you changed the fuel filter?
MikeyB
Old Feb 2, 2008 | 10:37 AM
i just installed an airdog 150 i should have plenty of fuel
Old Feb 2, 2008 | 08:15 PM
anybody ???
Old Feb 2, 2008 | 08:21 PM
nfsommer's Avatar
I cant wait for the thread about a blown motor
Old Feb 2, 2008 | 08:25 PM
#2 only's Avatar
WHY CAN'T YOU WAIT?
DO YOU WANT HIM TO BLOW HIS MOTOR?
Mr. Big Ram's Avatar
X 2!!...
Old Feb 2, 2008 | 08:26 PM
35" 05''s Avatar
Difference in air temperatures also makes Big changes. DO NOT go over 1500 on the egt's because u really dont want to know what that is in Cylinder temps. You should have ran it again and seen if it did any better. You really need a turbo if ur getting that hot.edit..and get rid of the k&n
Old Feb 2, 2008 | 10:37 PM
snoyes's Avatar
What changed between last time and this? Did you add a lift kit and bigger tires, how many miles have you put on the truck since last time at the drags? Where you launching in 4 hi? What was your reaction times? Temps outside do make big differences. 1600 is too hot. Really just a matter of time before damage is done, esp if you make multiple runs without letting it cool down.
Old Feb 2, 2008 | 11:17 PM
nfsommer's Avatar
Originally Posted by #2 only
WHY CAN'T YOU WAIT?
Actually, Yes i do..
MUST WE TALK LIKE THIS?
Old Feb 3, 2008 | 12:16 AM
Luvnacumns's Avatar
Too funny.... If you do some re-searching Tritan had some high temps while dragging and blew his motor.... Just a lesson to be learned...
