Nightmare installing EGT/Boost Gauge
Old Oct 4, 2004 | 07:44 PM
  #31
Lightman's Avatar
Billyram, I like the gauge, it's easy to read for me at least, and it's a combo which fits in the single pod on my srt-10 pillar. I just got a bum gauge, and westach is sending me a new one. Thanks for the suggestions and help all.
Old Oct 4, 2004 | 07:54 PM
  #32
Billy Ram's Avatar
Lightman
I hope they get you a good one soon after what you went through. Working on your truck is suposed to be relaxing and you want things to work after waiting for what you want. I like dealing with Geno's too.
Old Oct 4, 2004 | 07:56 PM
  #33
Lightman's Avatar
Genos was more than helpful, they are great to deal with.
Old Oct 4, 2004 | 10:42 PM
  #34
Holsteinman's Avatar
Lightman,
I hope everything goes better with your next gauge. I have the combo gauge and love it. It is easy to read, and I can read both with one glance. I admit I would have never bought one without seeing one in person. I was not sure it would be easy to read untill I saw one in person. Again good luck with the next one.
Old Oct 5, 2004 | 04:43 AM
  #35
Dodgezilla's Avatar
I like mine too. And it is easy to read.....
Old Oct 5, 2004 | 06:39 AM
  #36
TUGUM's Avatar
just put one in this weekend same problem.think my is a 3psi
Old Oct 5, 2004 | 08:08 AM
  #37
Lightman's Avatar
Just look at it this way, at least you didn't break off the end of your magnet tool in the manifold like I did!
Thats interesting you have the same problem. What did you use for the power source?
Old Oct 5, 2004 | 08:15 AM
  #38
TUGUM's Avatar
cig lighter,ihad to pull the ex manifold it wasn't bad though.
Old Oct 5, 2004 | 11:28 AM
  #39
Dodgezilla's Avatar
Man! You guys have too much time on your hands. I ran the wire out to the fuse panel and tapped into one of the fuses that comes on with the ignition.. No fuss! No muss!
Old Oct 5, 2004 | 11:49 AM
  #40
Lightman's Avatar
Zilla - it wasn't hard to take ONE screw out and pop the dash off to get to the cig lighter wire, or to take ZERO anything out to tap the brake controller wire. Hey you had to pop the fuse cover off!!
Old Oct 5, 2004 | 05:35 PM
  #41
Dodgezilla's Avatar
At least I didn't have to think in order to do mine! My brain can't take too much of that........
AND, I didn't have to go get a screwdriver ....
Old Oct 5, 2004 | 09:21 PM
  #42
Lightman's Avatar
But I got a reason to try out my new dewalt power driver. Yep one screw, but I was too excited to try out my new tool.
Old Oct 8, 2004 | 10:42 PM
  #43
dodgezilla04's Avatar
put dripocol gauges in mine, here is what Banks said to do with the drilling and tapping of the exhaust manifold. First, duct tape most of the exhaust tip closed, get you drills and tap ready, start the truck, and start making chips. the exhaust will blow the chips out of the hole so definately wear eye protection. I recommend hi temp gloves also, by the time you get to tapping, your hands will become quite hot. 4000 miles so far after install and no leaks or issues.
Old Oct 10, 2004 | 04:36 PM
  #44
Dave65's Avatar
I just installed the Westach Dual high performance gauge and I am having the same problem with the boost gauge,I have the 12 volt wire hooked direct to the accesories fuse and as soon as I hook up the ground the needle goes up to 2 1/2 or 3,so I checked the ground and tryed different spots and it still doing it.
I will try a different 12 volt spot.I just got this gauge from Genos.
Also the EGTs climb real fast with the EZ set on #4,I have stock exhaust and airbox,but it didnt go passed 1100 and doing about 70 on the expressway it was about 500 to 600 degrees,does this sound right?
My 2000 was post turbo so it acted different all together..
Old Oct 10, 2004 | 04:46 PM
  #45
Lightman's Avatar
Dave, that makes 3 of us now with defective gauges doing the same thing. Don't bother trying another source, this is becoming a consistent issue. Maybe a bad run of gauges. Who knows.
