New Turbo showed up today
Old Aug 2, 2010 | 06:50 PM
Rand1544's Avatar
Just recieved my new Thunder 330 turbo from II today, sure is pretty, cant wait to get it installed along with a CFM+ intake and II exhaust manifold. Thought I'd share with everyone.
Old Aug 2, 2010 | 07:28 PM
59c's Avatar
59c
sweet
Old Aug 3, 2010 | 10:26 PM
COUNTRYBOY's Avatar
Nice, what are the specs on your turbo?
Old Aug 4, 2010 | 01:06 AM
hotrod929's Avatar
Whats the difference between your Thunder 330 and the Silver 62? They both are a 62/74/14 and the only difference I see is the silver is a polished compressor housing. I am very interested to know the difference. Thanks
HotRod
Old Aug 6, 2010 | 07:56 AM
billcabral28's Avatar
i am interested in that turbo as well,give us your thoughts when you get installed
Old Aug 8, 2010 | 08:34 AM
Rand1544's Avatar
Well I tried to do as much research as possible before I purchased. I was told it was a much heavier duty turbo than the others, it has a 6 pad thrust instead of a 4, and a wider heavier duty journal bearings, and a heavy duty #40 waste gate instead of a #30. Was told it should spool about the same as stock with my setup. Should have it all done today. Ill keep you posted.
Old Aug 8, 2010 | 08:41 AM
Rand1544's Avatar
Also the other turbos required me to also get an HX40 downpipe for clearance issues, I already have an aftermarket down pipe. With this turbo I didnt have to spend the money on another one. This one is also rated to support higher horsepower numbers than the regular phat shaft.
Old Aug 8, 2010 | 01:51 PM
firemanram's Avatar
I had the Silver 62 on my truck for about a year & loved it. You will injoy
Old Aug 9, 2010 | 10:39 PM
Rand1544's Avatar
All installed and working great, spool up with my mods is very similar to stock except it pulls like a freight train and seems to keep going. I only have about 60 miles on it at this point and im trying to take it alittle easy to give it some break in time. I have already noticed my EGT's are down a good 200 to 250 degrees which I needed very bad. I'm going to need more fuel now because my coal is very thin now. So far I'm very impressed.
Old Aug 11, 2010 | 02:23 PM
rgnagy74's Avatar
How about an update!!! Still like it???
Old Aug 11, 2010 | 03:28 PM
DWeiler's Avatar
and what are spec/ size
DNRCustoms
Sep 26, 2008 11:04 PM
06 DIESEL
MDDTR #33
Nov 12, 2007 08:47 PM
88bird
Sep 23, 2006 11:29 PM
tobyw
13
Jun 26, 2003 10:33 PM
