New turbo & Edge
New turbo & Edge
I put a turbo on my truck thats supposed to boost in the 50 to 60 pound range and my edge attitude moniter is only reading a max of 41 pounds of boost? I set the edge to a max boost set point of 60 pounds. Anyone know why it wont go past 41pounds?
bluechrome hit the nail on the head the limiting factor on your reading in the edge unit is the fact that the stock map sensor does not read pressure over 40-41 psi. so you ether have to buy a map sensor that reads over 40psi and plug the edge into that map. the autometer electronic gauge uses such a map sensor. i don't remember if the hook ups are the same.
Ok feeling better now.. Now I know what im doing tomorrow. thanks again.
