New PML Diff Cover
Old Aug 3, 2010 | 04:25 PM
Thundercloud's Avatar
Question New PML Diff Cover
I am getting ready to purchase the PML diff cover for the rear and I was wondering if I need to get a new gasket or reuse the old one. Also how many quarts of fluid do I need to refill. The company says it holds 3/4 of a quart more then stock but how much is stock. Thanks in advance for you answers.
Old Aug 3, 2010 | 06:13 PM
lucey's Avatar
You can re-use the stock gasket for sure. My MagHytec holds 8 Litres, so not sure about the PML though. Sorry
Old Aug 3, 2010 | 07:47 PM
jlipskoc's Avatar
8 liters I think you mean 8 qts for Mag Hytec
Stock fills:
Rear differential – 122oz or 3.8qts
Front differential – 76oz or 2.38qts
Old Aug 3, 2010 | 09:13 PM
MikeyB's Avatar
Takes almost 5 quarts for the PML.
MikeyB
Old Aug 4, 2010 | 08:03 AM
LongRanger's Avatar
I just put one on, the stock gasket is stout, you should have no need to change it unless you damage it some way. Nice cover for the money.
Less than five quarts is what I remember. There is a guy on fleabay selling cases of Valvoline SynPower 75-90, I paid about $5 a quart. A lot better than close to $20 a quart for Amsoil locally.
Old Aug 4, 2010 | 10:12 PM
lucey's Avatar
Stock fills:
Thanks for the clarification ! I use 8 QTS = 8 L ! Sorry !
Old Aug 5, 2010 | 11:25 AM
Thanks to all those that replied. I order one from Geno's Garage but it is on back order. Yesterday I unscrewed the fill plug on the rear diff cover to see if it was filled to the correct amount and it is every so slightly above the fill hole as is comes out very slowly. It has a graphite color and smells like used gear oil (I guess). Just wondering if the color is normal as I have read on this site that some folks are milky color in appearance.
Old Aug 5, 2010 | 11:49 PM
Nate-03 D's Avatar
What do you mean by "graphite in color"? Like it's full of metal shavings? If it's just a darkish color your fine. Just check everything out real good when you pull the cover. Do you plan on filling it with synthetic? Since your in there that's going to be your best bet.
Old Aug 7, 2010 | 03:44 PM
No metal shaving s from the little I could see, just a dark grey color. I am planning on using Amsoil Severe Gear 75/90.
Old Aug 8, 2010 | 01:20 AM
05 CTD2500's Avatar
Mine looked the same way when I changed it for the first time, now it looks almost new when I change it. Think I remember someone saying its a break in additive? Anyway, feel a lot better having it look clean.
Old Aug 8, 2010 | 01:18 PM
Grey Wolf's Avatar
It's the paste that they use to set up the gears that gives it that color!
Old Aug 13, 2010 | 05:59 PM
Well I installed the cover and put in 4.5 quarts of Amsoil Servere Gear 75w90. Does the fill and level plugs take a 9mm Allen wrench or is it a SAE size? I used a large standard screwdriver to tighten those plugs up and it seem to work ok.
Old Aug 13, 2010 | 09:10 PM
jlipskoc's Avatar
Per my email to PML:
"The drain is 1/2-20 magnetic drain plug with a copper washer. Here is a
link that shows a picture, http://www.yourcovers.com/acc_dp-mag.php.
this uses a 9/16 socket wrench.
The fill & level check are 1/2-14 npt pipe plugs. I do not have a
picture of these. These use a allen wrench.
The cover for your vehicle is P/N 10361, here is a link,
http://www.yourcovers.com/diffcover_10361.php"
cditrani
13
Dec 4, 2005 09:42 PM
Lightman
Apr 18, 2005 02:09 PM
HighTen
Feb 23, 2005 02:51 PM
davelinde
31
Jan 28, 2005 05:38 PM
MikeyB
13
Jan 24, 2005 07:16 AM
