New Fass harness!
Old Nov 4, 2007 | 05:33 PM
bluechrome's Avatar
New Fass harness!
The new harness from fass is supposed to work with a relay Threw the original harness. So that it does not work threw any accessory power. Well the problem is fass wired the harness backwards so I had to take it apart and temporarily wire it the correct way and my fuel guage is stuck on a 1/4 tank. the problem with that I think is the harness that plugs into the tank /sending unit does not lock. I'm very un happy with fass's new solution with this harness. any seggestions would be great I need help.
Old Nov 4, 2007 | 06:13 PM
Ramtuff06's Avatar
Is running the pump through the cig. liter bad? Thats what fass recomends?
Old Nov 4, 2007 | 06:59 PM
bluechrome's Avatar
It's not bad but It stays running longer
Old Nov 5, 2007 | 05:14 PM
bluechrome's Avatar
Has anybody had problems with there sending units
Old Nov 5, 2007 | 06:18 PM
bluechrome's Avatar
Bump Bump!~!
Old Nov 6, 2007 | 04:04 PM
Diesel-Dan's Avatar
Is this the unit that Wally at Fast Track was working on?
IF not, here is what i went over with him:
The sending unit wires should be correct. They are just stright through...and im beting that it has something to do with why you can plug in the harness. Those plug ends are 100% the same as the one on the truck. My guess is the stock connector on the truck wire harness came apart and part of it stuck in the sending unit plug in. This letting you plug in to the harness side but not letting you plug into the tank side. My guess is you will find something keeping the plug from snaping in all the way.
As for the harness being backwards, what was exactly incorrect about it? I would like to know as you probaly have one of the first runs of this harness for the 05+ trucks. BUT if something is not correct, i would like to know what exactly was wrong so i can so some spot checking. I am feeling your case is an isolated isssue as i installed 2 the other week with no probs out the same stock your harness came from. For that, i am sorry.
Let me know if I can help any further......
Old Nov 6, 2007 | 04:17 PM
Diesel-Dan's Avatar
Its our new harness for the 05 trucks....we finaly located the plug ends for the sending unit and stock harness. These trucks will have a plug and play harness with a relay. WH-1004 is our part number.
Old Nov 6, 2007 | 04:46 PM
bluechrome's Avatar
Hay dan, That's me. The trigger wire was in the wrong position in the harness that plugs into the back of the relay. As I read the schematic on the relay And put the test light on the harness I found out the harness was wired backwards. I guess a simple mistake. But the sending unit harness has got me. I guess I'll pull the drive shaft down again and try to see what is wrong I must be a retard because three of us could not get it to work. On the relay topic I had to pull the wires out of the harness/plastic thing and plug the wires in manually to the relay I guess you talk to wally again today because I trashed the end of the harness that plugs back into relay So he said he would get another. Do you have any suggestions on getting the new harness to plug into the sending unit?
P.S. The pump does work great and is extremely quiet. But I would love to know how much fuel I have Though.
Old Nov 6, 2007 | 05:12 PM
Diesel-Dan's Avatar
Just talked to Wally. Our UPS already picked up for today...but i am going to run by the local UPS Store and drop you a new harness in the mail. Should have it by thrus.....AND this one should be correct...
Thanks bud......
Old Nov 6, 2007 | 05:20 PM
bluechrome's Avatar
Thanks dan good customer service is vital in a situation like this
1BAD4X4
Apr 20, 2008 01:45 PM
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
