Need quick advice. Should I run down and get my muffler removed?
Old Mar 5, 2008 | 04:20 PM
Rednecktastic's Avatar
Got some free time today. Was thinking of going to a 5 inch system later on in the year when I get my $600 from the govt.
Anyway I want to louden up my truck some now. Thinking of running it down to an exhaust shop and telling them to just throw a 4 inch pipe in place of the muffler on.
How much should I expect to spend and will this be annoyingly loud?
Old Mar 5, 2008 | 04:28 PM
Heh, calling around no one in town can bend 4 inch pipe ... Maybe this is a no go unless they can angle it in properly.
Old Mar 5, 2008 | 04:35 PM
trksrfun's Avatar
as far as noise and all that im not sure, but when i took my cousins truck to switch mufflers on that they did it for 20 bucks. his trucks gas but dont think it would make a difference... good luck
txfiremedic's Avatar
Howdy, I had mine done, cost about $75 bucks. Go do it!!
Old Mar 5, 2008 | 04:36 PM
06CTDforAU's Avatar
That was the problem I had. Nobody could bend 4" pipe. The shop that done mine just used a straight piece of pipe and angled it as much as possible. It pulled the tailpipe around just a tad, but looked good.
Old Mar 5, 2008 | 04:37 PM
kelley15's Avatar
Just get a straight piece of 4" and swell both ends then clamp it. It works fine this way.
Old Mar 5, 2008 | 04:45 PM
So they can angle it? Called like 15 places here and a couple towns over and none of them can bend 4 inch pipe.
Guess I'll get it angled and done this weekend since it's almost 5 now.
Also, it's not going to resonate the heck out of my truck on the freeway will it?
Old Mar 5, 2008 | 04:46 PM
No it sounds good.
Old Mar 5, 2008 | 04:59 PM
Pooter's Avatar
Cut an angle on both ends and itll line up just fine.
I did mine like that in my buddies driveway the 2nd day I had my '05, took about 4ft of pipe(cut some off to fit), cut appropriate angles on either side, then borrowed his welder and buttoned it up.
Old Mar 5, 2008 | 11:02 PM
Thanks yall... About time to open this thing up and let it sing I reckon.
Old Mar 5, 2008 | 11:09 PM
CReed's Avatar
Just put that $75 to 100 into you savings account for a 5" system factory straight pipe just gets annoying.
Old Mar 5, 2008 | 11:32 PM
redneckwilly's Avatar
cost me 80 bucks and that after they welded my magnaflow together since i just clamped it when i put it on myself. All they need is a straight piece of 4 inch pipe.
and the only time i find that the exhaust will drone is when im hauling and at about 1600 rpm on the highway while accelerating. Cant beat the sound!!
Old Mar 5, 2008 | 11:36 PM
i wouldn't pay $75 for someone to angle cut and weld in a 4 inch pipe. Maybe $40.
Old Mar 5, 2008 | 11:40 PM
durasnack's Avatar
we can do it with a torch and welder at a small shop just outside college station city limits for no charge at all this job takes place a couple times a month ...you supply the 4" pipe though
Old Mar 5, 2008 | 11:41 PM
Cool so they welded up the system and gave you some 4 inch pipe for 80.
