Need input, slow spool, low takeoff.
Old Aug 29, 2007 | 10:12 AM
Sixpack73's Avatar
i agree, just ease into the throttle and once you have a few psi of boost then you can hammer down. otherwise you're drowning the fire out with so much fuel and no air and actually get less power.
if you want to do a burnout, just power brake it to 5 psi, and simultaneously let off the brake and mash the peddle (in 2wd). It should light them tires up with no problem.
btw, not to derail the thread, but i wonder if there's a way to get more air in there right off idle? something like a small supercharger, or even a small shot of NOS (or O2 from a welding cylinder?) that gets shut off once the turbo is lit?
Old Aug 29, 2007 | 10:16 AM
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by cquestad
Never just mash the pedal...that is what stock fueling and stock turbos are for!
I cant lay into the throttle more than 1/4 till I hit 10 psi of boost...then hold on.
A downloader is the best way to get power down low...coupled with a MP-8 or a Quad. Make sure you are not throwing so much fuel that you drown the turbo.
When you say slow to light...are you smoking like mad till its lights or...no smoke?
I don't know about the others, but I am smoking like mad!! More so with the Smarty Beta than the regular programs. It's a good thing to have once in awhile
Old Aug 29, 2007 | 10:19 AM
soulezoo's Avatar
DTR 1st Sergeant
Hmm... nice idea. I was reading something somewhere talking about how superchargers for diesels were making a comeback. Old marine diesels used to use twin screw superchargers for quite awhile. Food for thought..
Old Aug 29, 2007 | 10:36 AM
05CTDN8's Avatar
I dont even smoke on level 3 of the race box. I try not to mash it. I know how to power brake it, but I want the pull me into the seat low end.
Old Aug 29, 2007 | 11:48 AM
chrleb1's Avatar
When going to bigger turbos, you need the stock stall. To low of a stall kills the spool up. Too loose also makes it not driveable. We mainly run a stock stall in Dave's converters.
Old Aug 29, 2007 | 10:29 PM
jgiachino's Avatar
Same her and agree!!
Old Aug 29, 2007 | 10:52 PM
Luvnacumns's Avatar
Wow with my stock turbo and 4.4 along with mp-8 I could hardle get it to smoke unless I lagged it really hard??? Now with the twins I can barely bet any smoke unless I hammer down.. I also only run the mp-8 on 40% too...
Old Aug 29, 2007 | 10:59 PM
gus's 03's Avatar
no low end boost issues w/ my setup....
i was lazy lugging it over the pass last weekend, 6% grade, 5400+ feet 1200rpm in 6th making 25 psi on stock turbo... i hate getting stuck behind people trying to tow travel trailors w/ an explorer...
schamran
Jul 17, 2012 09:50 AM
ramsport59
May 3, 2010 10:22 PM
Joe Diesel
Nov 12, 2007 08:59 AM
blakedill
May 12, 2005 10:35 PM
Cummins4u
Oct 19, 2002 07:47 AM
