Need help with wheel offset...
Need help with wheel offset and backspacing...
My wife doesn't care for my H2's and really wants me to replace them. So, I'm starting to look but can't remember what offset/backspacing the H2 wheels are. The wheels I like are 17x9 with 5.71" backspacing and +18mm offset. These will work, right?
I'm really just looking for verification before I order anything. I think the H2s are 8.5" wide with 5.5" backspacing. Will someone verify this for me?
As far as having my H2s, I'll gladly make you a smoking deal, if you're really interested.
What does your wife drive? My wife drives a Jeep Liberty and can do anything she wants to it. She doesn't bug me about my truck.
The H2 wheels do have a 5 1/2" backspace so the other wheels should work. I think the factory wheels have a 4.5" backspace, so the wheels you're looking at will stick out a little farther than the H2 wheels.
I think I'm in the market for a new wife
A 17x9 with 4.5" backspacing will stick out 1" further than a 17x9 with 5.5" backspacing. Refer to the picture below.
Finally, I'm pretty sure the stock wheels are 17x8 with 6" backspacing.
My wife says I spend too much $ on my truck, I spend too much time under my truck, I spend too much time W/ my truck, I spend too much time on the computer investigating things to do to my truck, she says my truck is too loud, rides too rough, sits too high, eats up too many tires...................
Not to complicate things more, but depending on hte wheel manufacturer backspacing and offset are two dif things. I went through thiswhen i put wheels on my last truck. You would think that this word be standardized . nope. After talking with the gus at Centerline about it, we figured out that they used offset while the factory wheel specs called for backspacing or vice versa and to tell you the truth, now I don't remember the dif in the two. If i can find the link, i will post it.
Yeah, they are different. Take a close look at the phot I posted above. With one you can pretty much figure out the other, not precisely but close enough to get the job done.
Anyway, I'm sticking with the stock wheels for now, mainly because I feel that a wheel with a greater offset is what causes considerable extra wear to your ball joints. The bigger tires contribute too, but not as much as a wheel that's centered farther away from your ball joints. Anyone agree/disagree with that?
I agree. It definately plays a role.
It looks to me like the wheels I'm looking at will stick out past the fenders about 1", which is where my H2s are now. I'm okay with that, I like the way the H2s look.
H2 wheels are 8.5 inches wide with 5.5 inches of BS.
OEM wheels are 8 inches wide (the alloy ones) with 6.5 inches of BS
You will like a 9 inch wide wheel with 5.75 inches of BS...as long as you are not trying to stuff 37's under the truck. 35's will be fine.
