need help spooling
Old Jan 25, 2008 | 01:12 AM
Goober's Avatar
need help spooling
I am having trouble spooling my 62/14 with just my mods. The turbo is not fully spooled untell 2500 rpms (35psi). I have the boost elbow closed all the way. I have thought about getting a smarty but i am not sure that will help any. You guys have any ideas.
Old Jan 25, 2008 | 01:31 AM
Kman9090's Avatar
You need a little more fuel maybe. 35 psi??? my stocker would run that. You should be getting more boost then that but maybe don't have enough fuel. You also need a boost fooler. If all else fails a Cam helps alot. I can spool a 66mm just as fast as a stocker.
Old Jan 25, 2008 | 02:17 AM
trik396's Avatar
I'd get a Diablosport predator and load up an Extreme RKL tune or a puff tune. If that doesn't spool your turbo, nothing will. My truck feels like it spools quicker than stock with my Silver64 and puff toon loaded. It smokes at idle a bit. Lotsa fun for sure.
Old Jan 25, 2008 | 08:07 AM
jgiachino's Avatar
Just need more fuel of your choice....smarty, bd, others should get it to light w/o issue.
Old Jan 25, 2008 | 10:00 AM
gsdog1's Avatar
Depending on what you do with the truck and what your goals are, a 12 cm exhaust housing may be more appropriate than the 14.
Old Jan 25, 2008 | 02:14 PM
Goober's Avatar
how hard would it be to put on a 12cm exhaust houseing.
i tow a lot. 2-5 a week. i blew my turbo and did not have time to fix it so i had a shop do the work. i asked for a 62/12 but i got a 14 and was not told about it untell i payed. should i work with this one or will it not tow as well as the 12 cm
Old Jan 25, 2008 | 02:33 PM
rip 112's Avatar
If you have an Automatic a 12cm housing will be much better than 14cm.
Have you considered upgrading to Quad Race?
Old Jan 25, 2008 | 02:50 PM
CReed's Avatar
Add a programer and that will pep it up.
Old Jan 25, 2008 | 05:05 PM
bluechrome's Avatar
Thats odd because When I had my 64/71/13 I had to drive my truck for a couple days on stock fueling do to a recorvery file on my smarty and I could hit 38 psi no prob. Thats odd
Old Jan 25, 2008 | 05:22 PM
omaharam's Avatar
He has an SO engine.
Old Jan 25, 2008 | 05:23 PM
bluechrome's Avatar
Good Point didn't catch that
TornDodge
Aug 14, 2008 12:35 AM
tristan21
Feb 23, 2006 05:47 PM
G-NOTE
23
Sep 8, 2005 09:25 AM
1ST GEN.
Mar 6, 2005 06:59 AM
racermatt2606
Jul 9, 2004 02:02 PM
