Need help batterys boiling acid.......
Ok 7 months ago i replaced the batterys because they where boiling acid and i had them check by a dealer and they said u need new batterys and so i replaced them and now they r doing that again. What could be the problem? The help would be very much appreciated..
I would check the cross over positive cable from the passenger to the drivers side. Any loose connection and you will boil over the passenger side battery. My advice would be to clean your connections on both batteries.
X2 - battery charge is monitored on 1 side & delivered on the other - loose connection on the crossover cable will do exactly that... cable itself is beefy enough to usually be fine.
moparman13045
13
Apr 27, 2008 08:54 AM
MR HYDROSEED
Jul 17, 2007 05:08 AM
