Need help in a bad way (cp3)
Old 04-08-2007, 01:07 PM
lmills's Avatar
ocassionally if the FCA is damaged, this will work to get it running. It will not run correct, but it may get it to fire off and help narrow it down
Old 04-08-2007, 01:38 PM
wap
wap's Avatar
Thanks, I will try that before anything else.
So, if it will fire, I guess I need to be ording an new fca?
Old 04-08-2007, 01:46 PM
lmills's Avatar
you got it. either way, it is sounding like the FCA is the problem.
Old 04-08-2007, 01:55 PM
wap
wap's Avatar
Awsome, that is what I am wanting to hear. I am praying it is just the FCA. Thanks Lloyd.
Old 04-08-2007, 04:37 PM
wap
wap's Avatar
Ok, I took the FCA off and it slid freely. This was after unhooking the sensor and tryin to crank it. I went ahead and made double sure everything was smooth and took the triangle valve piece back out and sanded it some more.
I put it back in and still no crank. It will turn over but no fire. I did notice that the end cap looks a little worse for the wear. Could that have anything to do with it?
I am kinda startin to get worried hear.
Should I try a new FCA? New cp3?
Help
PS I now have a 2509 and a 0251
Old 04-08-2007, 06:58 PM
973604x4's Avatar
0251 Injection Pump Metering Control A Malfunction
2509 ECM/PCM Power Input Signal Intermittent
(I had the 2509 code when my ECM fried. NOT trying to scare you, but you definitely have an electrical problem at hand!)
Old 04-08-2007, 07:38 PM
lmills's Avatar
I would try a new FCA first. How high was the rail pressure on your WOT run? The fact that it will not fire sounds like it is not building rail pressure. Unless the ECM sees a preset minimum pressure, it will not fire the injectors.
Old 04-08-2007, 08:07 PM
drewblood's Avatar
check your ground and power connections and fuses also check to see if any thing is shorting the ecm to ground possibly wrench or allen
Old 04-08-2007, 11:51 PM
Smkndzl's Avatar
I would at least check the rail relief valve by removing the banjo bolt from it and make sure the relief valve is not stuck open first.
Old 04-09-2007, 06:37 AM
wap
wap's Avatar
I THINK the 2059 is because I let the batteries get week trying to crank it.
I did drop my t30 socket and could not find it. But I didnt realy think it was a problem and didnt look that hard. I figured it would fall out.
Is is possible that, that is my problem??? When I really hammered on it, it could have made the t30 shift and is grounding the ECM??? CAN THAT FRY MY ECM???
Any tips on pullin my ECM off to see if anything is touching it?
Old 04-09-2007, 07:35 AM
trik396's Avatar
Don't know if this helps or matters but here goes.
Removing the FCA includes discarding the mounting bolts and using new ones. Remove and discard o-rings. Use new ones only. Shake FCA... it should rattle. If not, it's bad, replace. Apply light grease to new o-rings, make sure FCA is flush with mounting surface, then tighten bolts in two stages. CAUTION-do not wait between tightening stages- the new bolts might lose their ability to retain torque. 27inch pounds first, then 62 in-pnds.
Don't know why these bolts are such a specific application but it sounds like you can have problems if these directions aren't followed exactly.
If this is all common knowledge, sorry for wasting time. I've never read thru the whole modding the cp3 threads. Good luck.
Old 04-09-2007, 08:21 AM
wap
wap's Avatar
I appreciate it, and no, I did not use new bolts or O rings, and it was not common knowledge for me BUT I dont know how that could cause the truck to shut off abruptly. The truck ran fine for at least 20 minutes and I started it and shut it off 2 or 3 times before taking it out and runnin it for the 20 min.
I think I am gonna call Floor it today and also try and take my ecm off of the block and see if I can find a ground.
Also when I shake the FCA it does rattle.
Old 04-09-2007, 08:33 AM
Mark1si's Avatar
Mine doesnt rattle.
Old 04-09-2007, 08:41 AM
wap
wap's Avatar
Originally Posted by Mark1si
Mine doesnt rattle.
I thought it was supposed to rattle?
Old 04-09-2007, 08:45 AM
belgianmagic's Avatar
We need to put 'FCA' in definitions ...it's not there
Quick Reply: Need help in a bad way (cp3)
