Need brighter headlights!!!
Originally Posted by hognutz
Well there are proably 4 aproaches to take.
1. better bulbs (sylvania silverstars or something)
2. HID (expensive and not DOT if not facotry equiped)
3. projector headlights (many aftermarket out there not sure on qulity)
4. the option posted above.
you may consider a combination. run the bright box with silverstars or something like that. I think most very high end cars are HID projectors lights. I don't have much experiance with these options so i can't really give you much input on which is the way to go.
The only way to do HID is to replace the module in entirety.
Beware of higher wattage bulbs, as the factory wiring is often not up to the higher current. Melting your harness is no fun.
I've only found one projector headlight setup that looks proper to me. It actually uses an OEM Hella headlight module (straight off a European car), which has EXCELLENT beam pattern.
www.borealistruck.com
jh
HaulinBut
Oct 4, 2006 06:35 PM
My 03 HO
Jun 16, 2003 02:38 PM
SjLingenfelter
Mar 3, 2003 06:25 PM
Maddog
Jan 29, 2003 10:18 PM
