N-Fab Nerf Bars installed
Installed my Wheel to Wheel N-Fab Nerf Bars today. Did the install by myself.
Instead of holding the bars up and marking the holes, which is definately a 2 man job, I made a template and marked the holes on it then transferred them to the area to be drilled. Used a motor cycle lift to place the bars for mounting, worked real well. If you use the template technique be sure you check the mounting holes on each nerf bar, mine were different, off by about 1/2". All in all it was not too bad.
I have pictures but the options says I may not Post attachments. Why is this and who do I need to contact to have this feature activated??
I have pictures in my profile.
Donald A
Donald A
mopar440cu
Dec 30, 2012 08:06 PM
Jus Cruisin
21
Jan 31, 2007 08:32 AM
gerry
Feb 21, 2006 08:47 AM
Donald A
Feb 2, 2006 09:25 AM
