my input on the Revo 5.3
You just connect the box, change your setting and go on your way.
It says, writing to ECM or something like that then you just unplug.
Mine says "writing to memory" when I change options, but I was under the assumption that meant writing to the Smarty's memory (for use in the next ECM update)?
Maybe Bob or Marco can jump in to straighten this out. I think the whole point was to have a software that you didn't need to upload just to change that stuff.
if that's the case.... that sucks ! To have the ability to change those parameter without reloading is what I assumed Marco was after.
You make one run down the track and figured you'd like to try something else.... just change the settings and not the whole catcher tune.
When I did it at the track, my times changed and when going down the road, it ran differently once changed. It must have been my imagination
In thinking about it... you're likely right but, if you ask me.... that's completely pointless
I could be wrong but, that would be point less. Why wouldn't you just change the setting the next time you uploaded a program ?
I think the whole point of the software is to allow users to choose the options they want (timing, RP, TM, etc.) without having to update their Smarty from the computer. The 30-40 minute computer update is the part that sucks and with this new software you rarely (if ever) have to do it.
When you change options it stores the settings in the Smarty's memory and applies them to the next ECM update....whether that update is in the next 10 seconds or next week doesn't really matter. Marco said the only way to get those options into the ECM is with a regular ECM update.
It makes sense what you're saying but as I said..... it's pointless ??? Just do when you change program levels
It's definitely not pointless. Before you had to wait for 30-40 minutes for a complete computer update just to try another level of TM or timing. Now you can try any levels you want and only have to wait 5 minutes for an ECM update!
You can make the changes on the fly, they just will not load into the ecm.
