The Mighty Smarty
Old Apr 26, 2007 | 09:58 PM
Big T's Avatar
If you just run on 3 or 5 itwant hurt the turbo will it?
Old Apr 26, 2007 | 10:00 PM
O.T's Avatar
O.T
Originally Posted by dodgezilla04
the smarty fools with aftermarket turbo software. you could run a stocker with it, for a little while until it grenades. they say aftermarket, they mean it. with my turbo and the wild, and beta hot, i can way too easily hit 50psi. your stocker will not live with that program.
Alright so looking at my mods, what software would I load?
Thanks'
onetun
Old Apr 26, 2007 | 10:07 PM
Flame's Avatar
jggarrettllc.
Congrats on your new found power.
The smoke is cool huh?
Old Apr 27, 2007 | 04:56 AM
own1bigtruck's Avatar
Originally Posted by HorseHauler
so who has a video of the smarty on #1? I want to see how much smoke setting one puts out
I run mine on #2 all the time. #3 had more timing rattle than I liked. It only smokes visibly when the boost is very low and you romp on it. Just normal driving you hardly ever see any smoke, but im running cool duals also, so that may split it up enough to where you dont see it.
Old Apr 27, 2007 | 07:45 AM
TX_Diesel's Avatar
The smarty is safe to run on stock vehicles if you stay under level 5 right???
I need to know I was just fixing to order a commander and smarty then read this thread....
Old Apr 27, 2007 | 08:59 AM
jgiachino's Avatar
For an auto, level 3....to be safe on the trans....for a manual, level 5.....you'll be fine and have a very large smile!
Old Apr 27, 2007 | 09:44 AM
TX_Diesel's Avatar
Great! now i have to part with my money.....:-)
Old Apr 27, 2007 | 10:02 AM
jrussell's Avatar
I cannot get above 41psi with the aftermarket turbo program on #5 or #7. Quad (and many many others) say the stock turbo is fine up to 42psi so I don't see any problems with running it if that's the highest boost I can hit. We all know the turbo won't grenade at 40psi.
The only reason I tried the aftermarket turbo program is because the standard (non-boost fooling) software was unusable due to high EGT's. I couldn't even floor it on level #3 for a few seconds without EGT's soaring past 1400*. The stock 30-32psi of boost is not enough to cool all the extra fuel added by the Smarty.
I don't understand why the Smarty doesn't have a boost fooling version with a safe max boost still controlled by the WG??? Instead of increasing the max boost via the software they just disable the WG entirely. A version with 40psi of max boost limited by the WG would be the most ideal. Come on guys it can't be that hard!
Old Apr 27, 2007 | 10:07 AM
TX_Diesel's Avatar
So I should purchase the Quad Boost Fooler when I purchase the Smarty? My truck is stock and I wanted to run the Smarty at the most level 5. Of course I will probably try level 7 or 8 or 9 but not all the time, just once around the block as they say. LOL
Old Apr 27, 2007 | 10:11 AM
jrussell's Avatar
It seems you need to fool the boost somehow to be able to use all the power available. I just changed to the aftermarket turbo program instead of buying a Quad boost fooler. Figured it would be doing the same thing either way?
Does the Quad boost fooler disable the WG completely or does it just increase the max boost limit to ~42psi and still use the WG?
Old Apr 27, 2007 | 10:29 AM
JohnInNH's Avatar
Jrussell ... I have wanted a boost enhanced Smarty S/W (limited to 40-42 PSI) also....
With the Quad and Smarty for stock sticks and turbo I hit 45 psi (maybe more but I let off)
Agreed the stock turbo can deal with 35 psi easy and even 40 psi often if you don't bark it.
Wild and Moderate (stock sticks and stock turbo) would really benefit from a 40 PSI limited boost version
Till then ... I just keep my Quad in... (I may try the after market turbo version) However taking the Quad in and out is faster than swapping S/W in the ECU.
Old Apr 27, 2007 | 10:34 AM
tcr's Avatar
tcr
Originally Posted by ramtd02
any number on the smarty will produce smoke, except #0, and #1. #2-#9 will smoke!!!
I must say, on mine #1 roles a little coal 'til the turbo lites
Old Apr 27, 2007 | 10:45 AM
ramtd02's Avatar
Well I Meant SMOKe......Like a 12 valve with a #0 plate and the afc full foward!! LOL
Old Apr 27, 2007 | 02:21 PM
tcr's Avatar
tcr
Ahhhhh, You meant SMOKe!! My bad! It just let's out a little puff.
Old Apr 27, 2007 | 05:24 PM
Boz007's Avatar
Ive hit over 42psi with my stock turbo, Smarty w/original programming, and quad boost fooler.
