Manual transmission question
My friend has an '06 dually. Tryin' to find out what kind of power his manual trans can handle before we start doing any mods. I know the clutch will probably have to be changed, but what else? And what do y'all recommend for a clutch? Thanx.
I am wanting a Southbend OFE. When changin the clutch you should replace the dualmass flywheel with a single mass. Other than that change the oil to some high quality to try and reduce heat and thats about it.
My stock clutch held a 130 horse quad and later an mp8 with no worries. My currnet stack is a diff story.
I'm running the same stack as Wap. I set the MP-8 no higher than 25% and the TST at 3/2 and everything feels fine right now. I'm sure that if I "Enjoy" my newfound power that I will also need that clutch upgrade soon...
Check my sig.
The harder I pound on it, the more it wants. Note: These results are not typical. I dont know how my clutch or flywheel are holding up to this. I run with just one box mostly and it alone dynoed 428hp on the ground
DBroadhead
Jan 6, 2009 08:20 AM
ezdemon72
14
Jul 29, 2005 10:05 AM
IH8MYCAT
26
Mar 4, 2005 03:21 PM
adamroofer25
Aug 24, 2003 02:31 PM
