magnets in aluminum tranny pans
Old Oct 22, 2008 | 05:31 PM
davelinde's Avatar
I have an aluminum tranny pan and when I first swapped it out I forgot to move the magnet from my steel pan. The drain plug has a magnet and on fluid changes I have not seen too much material there.
I'm getting ready to drop the pan and do a filter change and I just ran across the bigger magnet from the steel pan which made me remember I forgot it before. Can I just put the magnet in the pan? It won't stick to the aluminum... Maybe JBweld it to the pan? or just let it rattle around? I guess I'm wondering if it might end up stuck to something on the bottom of the tranny and cause issues. Or maybe I just continue to use only the drain plug magnet?
What have you all done?
Old Oct 22, 2008 | 05:38 PM
paulb's Avatar
Drain plug works for me. It's easier to clean, and has always collected all of the band fuzz.
I wouldn't let the magnet rattle around no matter what.
Paul
Old Oct 22, 2008 | 06:47 PM
Tiara3100's Avatar
I installed a magnet in my using epoxy. just make sure you clean the aluminum with a solvent like break clean first.
Old Oct 28, 2008 | 07:57 PM
davelinde's Avatar
my drain plug only had a minor coating of fuzz so I skipped the bigger magnet again. thanx for the opinions.
mstep3
30
Apr 24, 2011 02:02 AM
cameroneod
Jul 5, 2008 09:54 AM
orcaburger
Sep 22, 2003 05:22 PM
