Low End Torque
Old Feb 20, 2004 | 08:11 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Originally posted by turbo59pwr
So purchasing the TST might not be a good Idea? I dont want to always have my truck broke down. Maybe you could put it on hp-4 and tq-8 that should give you some low end.
Throughout our testing, we simply cannot say enough about the bottom side torque of the TST box. In Power Level 2, torque enhancement level 1, the truck is a little quicker than it was with the Edge EZ in the 80HP setting. EGTs are cooler, and fuel pressure is higher.
I'm often beating around on the streets with TE set to 5 and power to 3. In this mode, I can easily grab 50 PSI of boost (KSB1B), and break all 6 tires loose on dry pavement in 4 wheel drive.
There are no injectors or boxes out there that can offer anywhere near that level of bottom side power. Will you break your truck with TE set to 9 and power set to 9? If you're not setup for it, yes. But if you use common sense, put the settings where your truck can hack it, you'll be fine. And there are settings where everyones truck can hack it. PL1, TE1 is mild setting that offers a nice kick in the pants, and improves highway economy (I got 1.5 mpg on our test truck).
Rod
Old Feb 20, 2004 | 01:07 PM
turbo59pwr's Avatar
Thanks everyone for all your inputs. The TST box seems like it might not be a bad way to go after hereing some of the facts. Just have to smart with it.
atch
Sep 4, 2007 07:29 PM
duddin10
Nov 19, 2006 12:25 AM
Hammer Down
Sep 4, 2006 01:05 PM
spitzair
Jan 24, 2006 03:42 PM
