Lorenz Leveling Kit Installed
I installed my Christmas gift and have a few questions. I disconnected the steering linkage bar at each wheel and was wondering if anyone has the torque specs for that. Also how necessary is an adjustable track bar? Thanks for the help
INSTALLATION
1. Install tie rod (2) to the left steering knuckle and
drag link. Install the nuts (1) and tighten to 54 N·m
(40 ft. lbs.) Then an additional 90°.
2. Remove the supports and lower the vehicle to the
surface. Center steering wheel and adjust toe,
(Refer to 2 - SUSPENSION/WHEEL ALIGNMENT -
STANDARD PROCEDURE).
3. After adjustment tighten tie rod adjustment sleeve
clamp bolts to 61 N·m (45 ft. lbs.).
According to the 2006 Factory Service Manual.
Sean will sell you a Thuren anodized trackbar. It will re-center your axle and provide a tighter feel to your steering.
did the lorenz leveling kit maybe 7k ago... plan on doing the trackbar within a month. i feel its needed anytime you raise the suspension. sean didnt recommend one when i asked, said the steering wasnt ff but maybe a half inch... but id do it if i were you.
Steveareno
Jun 3, 2009 05:43 PM
JRAPTOR04
89
Dec 24, 2007 11:31 AM
dodgintrouble
Oct 30, 2007 10:51 AM
hovisimo
30
Aug 21, 2007 05:41 PM
RyeThomas
Jun 10, 2007 04:16 PM
