Loops
Old May 31, 2007 | 12:53 AM
RamNu2's Avatar
Loops
I am haveing a problem understanding these. This is straight off the DHRA website.
Driveline:
In place of a cross member, in the vicinity of the front universal joint, all vehicles running 11.99 or
quicker must have a retainer loop with 360 degrees of enclosure, 1/4 inch minimum thickness and
two inches wide, or 7/8 inch by 0.065 inch welded steel tubing, securely mounted and located
within six inches of the front universal joint to support the drive shaft in the event of U-joint failure.
4WD vehicles must have a retainer loop matching above description installed for the front drive
shaft. Long-bed trucks with a carrier bearing must have loops as described above on both rear drive
shafts. Open drivelines passing any part of the driver’s body must be completely enclosed in 1/8
inch minimum thickness steel plate, securely mounted to the frame or frame structure
If I read thise right only vehicles faster than 11.99 need them.
Or is it all 4x4's need them. I just don't want o get there and need them if I decide to try my luck at the track. Any one have the rights and wrongs with the rules. Here is the link to all the rules also.
http://www.dhraonline.com/main/forms...ook-v2.7.4.pdf
Old May 31, 2007 | 07:28 AM
tbarbee1's Avatar
It looks like all vehicles 11.99 or faster. Not all 4wd vehicles only the ones 11.99 or faster. At least thats the way it reads to me.
Old May 31, 2007 | 10:20 AM
XLR8R's Avatar
Should be just for faster than 12 flat! (subject to tech's mood )
I feel your pain with the DHRA rulebook - I suspect it was written by IRS acolytes...
We can't get the '05 to fit into any of their classes w/o rebuilding it; the way we run it on the street and at the track, it has too many mods for hot street and not enough for Pro.
Best thing is to run a purpose-built truck!
What are you doing re the .375" bolts in the DP?
Old May 31, 2007 | 10:40 AM
ptgarcia's Avatar
I read it as all vehicles under 12.00 sec. need one and a sub-12.00 sec. 4wd needs a second one on the front driveshaft.
Old May 31, 2007 | 01:10 PM
RamNu2's Avatar
Thanks guys that is what I took it as. I guess I will get there and find out for sure.
getblown5.9
Dec 13, 2006 12:21 AM
Paul Winey
Competition / Pulls / OffRoad
Jan 26, 2006 10:22 AM
2500Ram
Oct 25, 2005 06:11 PM
Crimedog
Mar 7, 2005 09:05 PM
JMull
Aug 3, 2003 09:19 PM
