Looking for pics of 265/70-17 on Dually
Old Nov 5, 2006 | 10:51 PM
RAT_03's Avatar
DTR's "Secret Agent"
no rubbing with W.F.O. 285s either
Old Nov 6, 2006 | 06:33 AM
wap's Avatar
wap
Both those with the 285s are sharp, I want a set of terra grapplers bad but until they make at least a 305 (I would prefer 315s) I guess Im out of luck.
Old Nov 6, 2006 | 08:00 AM
abc4yew's Avatar
I guess it depends alot on what tires you use.....265 Toyo OC A/T seem like they will be ok maybe even the 285's.....my 265 Cooper Disc. S.T are too close to tow heavy unless I crank the pressure up. I'll take a pic when I go out to change injector 6 again. Check the tire overall width to make sure they will fit. ks
Old Nov 6, 2006 | 11:57 AM
Boykid88's Avatar
I run Pro Comp 265/70/17's on my 04 at 45psi and with 300 gallons of water on the back they will rub. I have a set of 8mm spacers but it sets the outer rim off the centering hub so balance is less than perfect. If I run 65psi or higher they won't rub but the ride is considereably worse and center wear is horrible.
Check out my gallery for some pics.
HDBeauty
20
Dec 19, 2006 09:14 AM
RedRam410
Nov 15, 2006 09:20 PM
willy1947
14
Sep 29, 2006 05:22 PM
abc4yew
14
Dec 13, 2004 07:40 PM
TE-44
Oct 30, 2003 11:06 PM
