looking for advice
looking for advice
im sure you heard this before but, i need some advice. my truck with ez on 4 and tst on 5/5 from a dead stop 1st gear has a popping feal and sound like if i was hitting rev limiter. also the truck feals faster on level 4/4. does that make sense? please help with any ideas hoe i can fix this problem. thanks
it could be faster on 4/4. the tst will drop fuel pressure to 0 leaving the rail without fuel with the stock lift pump. then add the ez trying to boost rail pressure, without fuel to do so. I think many CR cummins guys should be thankful the cp3 does not fail like the vp44 did when subjected to low fuel pressures. any vibration with it? get worse slowing down?
You need to turn the EZ down to level 2 or 3. That's way too much pressure and you are sucking the fuel rail dry. You need a FASS or some other aftermarket fuel pump too if you're gonna run that stack. I run my EZ on level 3 and can go up to 6/6 on the TST before I start running out of fuel....
how much was that? without the edge i had bad lag so i didnt want to turn it down. ill try level 3 and see, do you have a fuel pressure guage on yous and that how you can tell its loosing pressure? thanks
89dieselkong
Feb 12, 2010 12:47 AM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
ryan466
Aug 30, 2006 10:10 AM
Steve5.9L
Sep 29, 2003 11:36 AM
mod cp3 soon?
