Long crank no start will start by roll start
Old Oct 9, 2008 | 08:10 PM
CoolumConst's Avatar
This truck will crank with no start. If we push start it will fire no problem. Any ideas.
Old Oct 9, 2008 | 08:13 PM
king d's Avatar
have you tested the batterys?
Old Oct 9, 2008 | 08:16 PM
been replaced.
Old Oct 9, 2008 | 09:04 PM
Old Smoky's Avatar
it would be interesting to see what rail pressure is while cranking. any codes? has it been getting hard to start for a while, or just all of the sudden wouldn't start? wondering if the rail pressure valve is wasted, or if there is excessive injector return....
Old Oct 9, 2008 | 10:06 PM
rip 112's Avatar
Starter engaging the same speed as before?
Old Oct 10, 2008 | 09:34 AM
Starter seems to still crank good. It sometimes starts after cranking for awhile but the breakers for the starting system start tripping. I am thinking rail pressure problem. We have two trucks at work that have this problem and our dodge mechanics are basically parts changers (drives me crazy that they do not know a thing about dodges) I told him the rail relief or rail pressure sensor. If the pump is returning too much fuel is that through the rail or is there a return line from the pump.
Old Oct 11, 2008 | 09:31 PM
Brian Lent's Avatar
check the connector tubes. Happened to me twice. the first time one was damaged . Have to have 10,000psi to start. The second time they just needed re-torqued. hope this helps.
Old Oct 11, 2008 | 09:44 PM
Rpainter's Avatar
10,000 to startmight want to check the books again need 3 to 5,000 to get the injectors to fire. most trucks idle at 6,000 to 7,500
Old Oct 11, 2008 | 09:50 PM
Brian Lent's Avatar
Put a snap-on scanner on your truck and crank it over. Won't start till it hits 10,000. Mine also idles at 6,000. I've seen it with my own eyes twice. Just trying to help.
Old Oct 11, 2008 | 10:00 PM
rich's Avatar
i would supect the injectors or rail pressure sensor. just replaced them on the 06. if its blowing a lot of black smoke and rattles its the injectors if not probably rail pressure valve
RIRAM
16
Dec 5, 2009 10:04 PM
Cummins610
Nov 14, 2008 09:48 AM
streetsmoker
14
Nov 6, 2007 02:58 AM
jaybone
Oct 13, 2006 10:55 AM
JW3
Dec 26, 2005 07:10 PM
