Load Ratings on Tires
Old Dec 19, 2006 | 05:04 PM
morkable's Avatar
I would like to go to toyos,, but the budget isnt allowing for that right at the moment. That is why I am wondering so much about if these tires will work
Kevin
Old Dec 19, 2006 | 05:11 PM
ptgarcia's Avatar
Originally Posted by morkable
But if I dont plan on carrying anything other than my 5th do you think it will work?
Kevin
Kevin
Yeah, they'll work.
Old Dec 19, 2006 | 05:47 PM
Thundercloud's Avatar
Kevin
I understand that you are not towing your 5th wheel that much (4-5 times per year) BUT it only takes one thing to go wrong and have a catastrophic failure. It is not worth it to me or more importantly the occupants of my vehicle to run a lesser tire than what came on the truck.
Old Dec 19, 2006 | 06:09 PM
morkable's Avatar
I hear you thundercloud, but what were the origional tires the bfg 265's I cant think that they were much more,, I am totally oblivious to how much the rating was on them
Kevin
Old Dec 19, 2006 | 06:24 PM
ptgarcia's Avatar
The stock 265s are rated for 3195 lbs.
Old Dec 19, 2006 | 06:33 PM
morkable's Avatar
Thanks Pauly, I appreciate it,, what is the load rating on the toyo 285 that I am running now?
Kevin
Old Dec 19, 2006 | 06:45 PM
ptgarcia's Avatar
Kevin
You're welcome.
Which model tire are you running?
Old Dec 19, 2006 | 06:48 PM
ptgarcia's Avatar
Never mind, I see its the Open Country AT.
They have a D-rated tire good for 3195 lbs and an E-rated good for 3750 lbs. You'll have to check the sidewall of your tire to see which one you have.
Old Dec 19, 2006 | 06:49 PM
Festus's Avatar
Kevin
3195lbs according to Toyo's website.
Old Dec 19, 2006 | 08:03 PM
J&L's Avatar
J&L
Kevin
Kevin------ something to keep in mind when gettin' new tires is Dodge recommends a load range "E" for our 2500 trucks [3500 SRW]. Dropping back to a load range "D" is derating your load range. You may be only carring a heavy 5er 4 or 5 times a year but it only takes once to have a "problem" from under rated load range tires. I've hauled commercial trailers moving my material and equipment to the next job site and will not use a "D" rated tire on any of my 2500/3500 SRW trucks. We did run the "D" on the DRW trucks but with 4 tires on the rear we had no probs.
If your not hauling heavy a "D" rated tire will work just fine.
JIM
Old Dec 19, 2006 | 10:49 PM
morkable's Avatar
Thanks so much for the input everyone, I am so up in the air,, I not the kind of person to do things half way,, but I want 20's so bad, and at the price I can get these sumitomos it is hard to say no,, I am going to have to take some time and think about it some more
Kevin
MERRY XMAS
Festus's Avatar
The D rated / 3195 lbs. / 65 psi are the only ones available in Canada.
Old Dec 19, 2006 | 11:07 PM
ptgarcia's Avatar
That may be case here also, I just pulled the info off their webpage.
Old Dec 19, 2006 | 11:10 PM
Festus's Avatar
Oh no. You can get the E rated in the US. It's a Toyo thing - they're available in the US, but not accessible to Canadian dealers. I've located some in the US. The prblem is that the company doesn't ship to Canada.
In "Performance and Accessories", I've started a thread to find someone to pick 'em up and ship them to me.
Morkable - If someone offers to pick them up and ship, do you want a set??
CalypsoCowboy
Feb 13, 2009 06:31 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
CapnCrunch
Sep 5, 2005 12:13 AM
99 cummins
19
Mar 21, 2005 07:49 AM
