Lift and tires final descion
Old Mar 10, 2008 | 09:34 AM
mudder500's Avatar
Alright since i want a 4 but all my buddies want me to get a 6 heres my setup. Tell me what u think.
6 inch revtek 1100 shipped upgrade to bilstiens later
37-13.5-17 toyo mt's 1240 shipped
Ultra goliath black 17x8 ( 5.25bs) 600 shipped
Will be ordering this in hopefully next week when i get my income tax back
Old Mar 10, 2008 | 01:10 PM
Lsufan78's Avatar
do they make those wheels any wider?? the ONLY problem i see is the 8" wheel with a 13.5" tire. it may cause a little uneven tire wear in the middle, but maybe you can just adjust your air pressure accordingly. other than that, sounds like you've got everything ironed out...order it up, get it installed, and take some pictures!!
Old Mar 10, 2008 | 01:48 PM
molalla1ton's Avatar
Your going to like the revtek lift. that is what I have and it rides really good. I have had it on well over a year and is holding up great.
Old Mar 10, 2008 | 03:01 PM
chipmonk's Avatar
x2...... 13.50 is a pretty wide tire for an 8" wheel. good luck......
Old Mar 10, 2008 | 05:15 PM
ryfrat's Avatar
You might have problems with the 17 rubbing the inside weights off on the caliper.I did,go with atleast 18's.
Old Mar 10, 2008 | 05:43 PM
snoyes's Avatar
I wouldn't mount 13.50s on an 8 inch rim. I would look for at least 9 or 10 inch wide rim.
Mindy's Avatar
^ I have 17's and no problems...
And that rim is definitely not wide enough...waste that rubber. Mine are 9 and I thought was cutting it close.
Old Mar 10, 2008 | 05:44 PM
Mindy's Avatar
Oh and do you have a megacab?? If so...factor in about 150 for the transfer case drop kit.
Old Mar 10, 2008 | 09:59 PM
mudder500's Avatar
naw its a quad cab. ok seems like i need to find some wider wheels. I'll see what i can do.
Old Mar 10, 2008 | 10:02 PM
mudder500's Avatar
I had 35's on xd hoss and never had a weight problem with 17's. Sounds like someone didnt balance them right.
Old Mar 10, 2008 | 10:12 PM
BossHogg's Avatar
Well I have H2's and I know what they are talking about with the rubbing. When I take mine to Discount, they put the weights where they rub every time, even when I tell them!
Old Mar 10, 2008 | 10:28 PM
mudder500's Avatar
yep. i worked at firestone for 3 years and had to tell them not to do that.
but on a good note i found toyo 37's on 18 to my door for 1114
Old Mar 10, 2008 | 10:58 PM
mudder500's Avatar
well i ordered them. 1118.39 to my door for 37-13.50-18 toyos mts.
not too bad
Old Mar 11, 2008 | 01:00 AM
mudder500's Avatar
Well so far i got lift and tires but no wheels!!!!!!!
Im either thinking of the xd hoss, xd monster or the helo 835 black and machine. these all have the 5.7 backspacing with 18x9 wheel
Old Mar 11, 2008 | 10:15 AM
01smoker's Avatar
Thats a good deal on those tires. Where are you getting them from?
