Latest and greatest fuel pump system?
Old Apr 24, 2014 | 09:58 AM
hoot's Avatar
Currently running a FASS 150 circa 2007.
Today I have no pump. Batteries test 12.43v
Connector at the FASS pump gives me 12.1v until the ECM timer cuts the power off.
I banged on the FASS pump with a hammer. No go.
Do I buy whatever the latest and greatest or just get a new motor?
Thanks. Mike
Old Apr 24, 2014 | 10:10 AM
soulezoo's Avatar
DTR 1st Sergeant
new motor.
Likely the brushes are wore out, it may be possible to have the motor reconditioned if you have a motor shop handy to you.
Otherwise, I'd contact Lary here and see what he can do for setting you up with a new motor.
There is really nothing on the market that is "gee-whiz" better than what you have now.
Old Apr 24, 2014 | 10:35 AM
hoot's Avatar
Thanks for the quick and honest response. Will contact Lary
Old Apr 24, 2014 | 10:43 AM
hoot's Avatar
I thought it was interesting that the truck runs fine without the pump. I just noticed when I turned the key on this morning there was no noise.
On edit... talked to someone at FASS. Said it would be fine till I get the new motor just no long trips.
Old Apr 24, 2014 | 11:24 AM
DFD536's Avatar
Mine ran for about a week while waiting to install a new pump.. Now my injector pump is toast. I would let it sit until it's fixed.
Old Apr 24, 2014 | 11:43 AM
hoot's Avatar
Well I can't get a replacement motor. Back ordered till May sometime. Is this some sort of cruel joke?
Old Apr 24, 2014 | 11:57 AM
DFD536's Avatar
Sorry to hear that... Nope not a joke. The lift pump has to maintain pressure to the injector pump. If I understand correctly, that pressure is how the injector pump stays lubricated. When I called a local Cummins shop, and told them I had replaced the lift pump, his first statement was I now would need a new injector pump. Went elsewhere to get the diagnostic to be sure and it seems that's what I'm looking at. Might be cheaper to buy a new lift pump than wait for the motor for your current one and risk the Injector pump.
Sorry for the bad news!
Old Apr 24, 2014 | 12:00 PM
hoot's Avatar
I keep hearing conflicting stories. I know the CP3 has it's own internal gear lift pump. The early Duramax trucks didn't have an external lift pump.
Old Apr 24, 2014 | 12:53 PM
hoot's Avatar
Just found out that FASS no longer supports my unit. Heard they are not making a replacement pump for it and are telling dealers to sell a newer complete unit.
Every single lead I got on Google is a dead end.
Old Apr 28, 2014 | 09:18 PM
Asher's Avatar
If your wallet can handle the cost, I would go with a mechanical (motor driven) pump... I don't know if Opie still offers his, but that is the route I would go... Nothing electrical is going to last as long as a motor driven unit..
Old Apr 29, 2014 | 05:27 AM
RyeThomas's Avatar
Winner winner chicken dinner!
GDP Fuel Boss is sold here by Larry and is an awesome mechanical pump.Since you were running a Fass you can piece together a kit and save some cash.
The only other option I would look at is Fuelab, they are brushless electric pumps. Problem is they are very pricey.
Intelligent Engineering aka Opie no longer makes the Mitusa mechanical pump.
GDP for the win!
Old Apr 29, 2014 | 09:54 AM
soulezoo's Avatar
DTR 1st Sergeant
Frankly the easiest solution is rebulding your motor by the sounds of it.
While the cp3 can suck the fuel without the pump, and it is true older Dmaxs had no pump (they also use a different- while similar- cp3) it is also true that you can/will burn your pump up in short order by running it without the lift pump. Just don't do it.
Old Apr 29, 2014 | 11:11 AM
Bradleyras's Avatar
Sorry I'm new here, I did a search for "Larry" and got 654684654684615164 results.
Does "Larry" have a website?
Old Apr 29, 2014 | 11:43 AM
RyeThomas's Avatar
Go up top and hit DTR store or Marketplace, it will give you Top's aka Lary's contact info. He runs the site .
Old Apr 29, 2014 | 12:23 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I do indeed with about 5000 more products than you see in the store here... http://www.dodge-diesel.org/
If I can be of any help let me know
