Lacking top end?
Old Jan 27, 2007 | 01:13 PM
acook's Avatar
Lacking top end?
My truck feels really strong right now, expecially in 1st and 2st, after that it seems a little slugish. I'm running the crazy larry/ez. Someone told be to get a boost fooler because my trucks defueling(I'm running about 57lbs of boost). Would this be the key? Or should i look at different programing?
Old Jan 27, 2007 | 01:29 PM
D.Wiggs's Avatar
I just went out to my truck to check, and I was right, I do NOT have 2st gear! I looked everywhere but coudln't find it. I only have 1st, 2nd, 3rd, 4th, 5th, and 6th. I am sorry I couldn't be more helpful!
J/K
Old Jan 27, 2007 | 01:41 PM
acook's Avatar
Yeah, thats probably why im not an English major! lol
Old Jan 27, 2007 | 02:19 PM
DrDiesel's Avatar
Wink
How many miles on the fuel filter. Reading you truck info is obnoxious.
I see you have lots O power adder stuff , but nothing to keep the fuel supply adequate...HmMMM. Check the fuel filter(s) and get a FASS... The 2MK filters will restrict early due to high efficeency.
Old Jan 27, 2007 | 02:21 PM
D.Wiggs's Avatar
Another thing could be the cams. I know that the cam makes a huge difference with top-end.
Old Jan 27, 2007 | 02:48 PM
blh1972's Avatar
Fuel?
He doesn't need a fass, He already has a Glacier fuel system
Old Jan 27, 2007 | 03:06 PM
WUnderwood's Avatar
do you have a rail gauge?
Old Jan 27, 2007 | 04:39 PM
acook's Avatar
I put a new filter(GDP MK2) on about 3K ago, along with their 392 comp pump and big line so im getting quite a bit of fuel. I do not have a rail guage, although i plan on it.
Old Jan 27, 2007 | 05:37 PM
acook's Avatar
Any ideas about weather a boost fooler will help the defueling(if it is in fact defueling)
Old Jan 27, 2007 | 11:31 PM
acook's Avatar
Bump(filling space 2 meet requirment)
Old Jan 28, 2007 | 02:12 AM
morkable's Avatar
acook, has your area changed over to usld lately? If it has you will need to up the detergent in your fuel and change all filters often, as the new fuel has alot more detergents in it. Just a thought
Kevin
Old Jan 28, 2007 | 06:07 AM
Dodgezilla's Avatar
I'm pretty sure the EZ does Boost Fooling in your 06.
My top end sucks too. Heck, with my setup I can't even get more than 35psi and I have to turn the Quad on the high setting to get that.....
Old Jan 28, 2007 | 08:54 AM
king d's Avatar
i get this exact thing sometimes if i check i usuualy have an overboost code,clear it and power is back were it should be,the boost fooler should help
Old Jan 28, 2007 | 08:56 AM
goodeyesniper75's Avatar
adding the quad to mine added top end
Old Jan 28, 2007 | 10:46 AM
Luken's Avatar
Top end?.... Put a tst on the truck.
