Just installed a smarty jr.
Picked it up from a board member, thanks again Bob, uploaded the middle setting with no timming or torque adj, very impressed with it, whole different truck now, if your on the fence about buying one , pull the trigger and get one.
It has the 5.09 version in it, should I update or leave it alone ? also my fuel pump would cycle off after a few seconds after turning the key on without starting the truck, now it runs constant with the key on without starting, is this normal ? And I heard a ticking sound when I was uploading and then it stopped when the uploading was finished, this also normal ?
Not quite sure about the timming and torque settings yet, really impressed with the 70 hp setting
On whether to update or not, read this thread and see if it helps you make up your mind. https://www.dieseltruckresource.com/...pdating+smarty
namotuman
20
Jan 23, 2010 09:44 AM
rebel102285
14
May 27, 2009 11:30 AM
kerry2
Apr 2, 2008 11:17 AM
trx
Aug 21, 2007 09:24 PM
