ISSPro turbo temp monitor install...
Old May 9, 2007 | 01:48 PM
timber's Avatar
Looking for some input from those who have installed one of these units on a 2006. I went to the ignition switch and found a black/gray trace, 16(?) ga wire that is hot with the key off. This doesn't fit the description I've got from a search of the forum or the place where I bought it. I'm not seeing a big, red wire in the bundle. Just want to make sure I'm headed in the right direction before moving on.
Old May 11, 2007 | 03:25 PM
bpdp379's Avatar
https://www.dieseltruckresource.com/...3&postcount=10
Old May 11, 2007 | 10:12 PM
timber's Avatar
Thanks for the link. Appreciate you taking the time to post it. I did find some info when doing a search on the forum but nothing specific to a 2006.
Still not having much luck. Found the unswitched power wire-no problem. Not having much luck finding the ignition wire. I uncovered the steering column and checked the wires at the ignition switch. I'm a little tentative with this method of finding the wires. Doesn't seem right poking around like that on a $40K truck full of electronics! I gave David at DM a call the other morning and thinking I'll have to make another in the morning.
BlackSheep5
13
Apr 4, 2007 11:15 PM
bpdp379
Feb 17, 2007 01:35 PM
RAFTEN
Jun 18, 2005 06:47 PM
rattle_rattle
Jun 28, 2003 11:48 AM
