ISSPRO Gauge install help needed
Old Mar 18, 2011 | 06:05 PM
easinc's Avatar
I located the Ignition Switch Power and tapped into that for the EGT Amp, but I can’t get good access to the Headlight Switch wires (for gauge illumination) going at it from under the dash. Tried to remove the left dash panel where the door meets, but it doesn’t appear to be a ‘pop out’ panel. Same thing with the headlight switch itself - doesn’t appear to be ‘pop outable’.
What is the best way to gain access to these wires? Model year is 2007.
Alternatively, if I decide to go to the fusebox in the engine compartment, is fuse 35 “ICC Illumination” the dimmer switch fuse?
Old Mar 18, 2011 | 06:42 PM
dott's Avatar
Ashtray light?
Old Mar 18, 2011 | 07:02 PM
easinc's Avatar
Originally Posted by dott
Ashtray light?
Unfortunately no ashtray in the 2007
Old Mar 18, 2011 | 09:03 PM
dan33900's Avatar
The side panel just pops off. Use a trim removalntool or flat head screw driver. That's where I wired mine.
Old Mar 18, 2011 | 09:36 PM
easinc's Avatar
The left side panel of the dash - where it meets the door when closed?
Old Mar 19, 2011 | 07:16 PM
easinc's Avatar
Was able to get that panel off and get at the wires. Thanks
Old Mar 19, 2011 | 09:05 PM
bziggy's Avatar
Just a word of advise. I don't know how many gauges you are putting on the light circuit but I would wire in a relay so you don't overload the lighting circuit. I try to use relays on every thing this way if something goes wrong with what you added it dose not effect you factory lighting circuit.
Old Mar 19, 2011 | 11:27 PM
NavyDood's Avatar
My Pyro and Tranny Temp control boxes are tied into the cig lighter +pos line with a 2a fuse, no Relay and have never blown the fuse. The lighting for my three gauges are all tied together on the same dimmer wire with no fuse. My setup has been this way for 5+ yrs and 100,000+ miles. I have never had a single hiccup and the original bulbs are still installed.
Old Mar 20, 2011 | 02:04 PM
easinc's Avatar
Finally finished installing the ISSPRO triple gauge set (Fuel, EGT, and Boost). The install went well. There were a few glitches, but all in all it went ok. Some steps were more involved than I thought they would be, others were easier than I anticipated. It did take about 20 hours to complete (time includes runs to home depot, local hardware, and auto parts stores).
Although the instructions that came with the set from DieselManor were good, I would not have been able to complete the project without all the information available on this site. Thanks to all who have taken the time to post about their personal install issues and solutions.
nvr-enuf
Apr 18, 2010 11:19 AM
RamrBob
Jan 17, 2008 06:25 AM
rjm022
Apr 29, 2007 09:34 PM
Mountainmac
Nov 6, 2006 01:15 AM
dctoner
Jul 27, 2005 10:17 PM
