Intake Manifold Tests Complete
we use an eddy current dyno that loads the roller via an electro magnet. For these tests, I set the load at 10% of its capacity and left it on for the whole run. This just helps simulate the weight of the vehicle a little and helps the boost come up more quickly
I built my own elbow and I certainly believe those dyno numbers. Now I can see why the low end feels so much more improved than the top end. I think it will just take more top end fueling to make the top end feel like it's in accordance with the low end and get the top end egt back up where it was. Craig
Andy
I would imagine a nice stainless or aluminum mandrel 4" pipe would get the job done. I know there is a guy on TDR talking about making one. Definitely not as advanced as the ones tested, but I believe it would still make improvements
Yes, 7 has yielded the best results on my truck and its the way I normally drive it. I actually lost a little on 9 the last time I ran it. I am pulling fuel pressure to 3psi on #7, so until I get the FASS installed, 7 is all I got.
Oh i see, thats still a lot of dough for only 10 or so peak hp gain, but the diff. in it makes in the lower range is really impressive. I wonder if this is more noticable in say a 6 spd. truck due to its always falling way down and having to build up again 4 or 5 times through the gears? Just a thought - Seems an auto keeps every thing tighter in its rpm band. Thoughts???
Moss Magnussen says they would have to prove it caused a problem, and I think they would have a hard time with that.
The 6-speed question is a good one. I *think* opening up the intake tract has helped the turbo spool faster, so that should be good for the 6-gunners.
I didn't buy the cfm+ for performance but more for looks. I agree it helps some, but not alot, just eases the wear and tear process by allowing the potential of cooler air. I do enjoy having low egts though, even at wot I rarely see over 1100*.
I agree with the sentiment here that that is a nice article and test. I am about to buy one so the article is very timely for me. I really haven't considered the CFM until now. I was looking hard at the AFE Bladerunner and the GDP. I think they are ALL overpriced!
