intake
Old Feb 9, 2007 | 01:43 AM
oneslowyfz's Avatar
intake
i am looking into buying the afe stg2 or the s&b and i poped my hood and there are a few things that came to my attention, do these aftermarket intake have places for the sensors/ the greend and yellow thing whatever the hell it is? and if they dont will i get a code/ check engine light? thanks for the help
Old Feb 9, 2007 | 02:40 AM
Its All Good's Avatar
I know my AFE stg2 has a place for the sensor.
Old Feb 9, 2007 | 06:59 AM
JOECUMNS's Avatar
I've got the S&B and it has the place to install the Intake Air Temp Sensor, the other is a filter minder and you don't need it with the S&B cause you can see the filter through the clear top on the box. Very good intake especially for the $$$.
Remove the silencer ring going into the turbo while your at it and get more whistle from the turbo.
Old Feb 9, 2007 | 07:21 AM
Arkapigdiesel's Avatar
All of the aftermarket intakes have a place for the restriction-o-meter and the AI sensor. If the AI sensor isn't hooked up your CEL will come on.
Old Feb 9, 2007 | 07:26 AM
telephonman's Avatar
Whatever intake you go with you will need to use the sensor and the filter minder, you can't tell by looking at the filter how much retsriction is there, no matter how dirty or clean the filter looks.
Old Feb 9, 2007 | 10:31 AM
oneslowyfz's Avatar
so then i do need to hook up the filter minder which is the green and yellow jar the s&b does not have that and the afe does?
Old Feb 9, 2007 | 10:32 AM
morkable's Avatar
Where did you put in your restriction meter? I have the afe, and i didnt see anyplace to put in the restriction thing.
Kevin
D45
17
Dec 6, 2007 01:52 PM
natlchamp2k4
Mar 13, 2007 05:47 AM
BA05'CTD
Jan 7, 2007 03:08 PM
dodgezilla04
Jul 1, 2006 01:28 AM
Bobcat698
Sep 24, 2005 10:51 AM
