Installed Silvania Silverstar Headlights
Old Nov 29, 2004 | 06:31 PM
Jmac's Avatar
This was not in any way shape or form an easy task. I would have rather wrestled a gorilla!!!
Having said that they work great... I also put a couple of washers on the top housing screw to point the beams down a little.
Jamie
Old Nov 29, 2004 | 06:49 PM
RichSax's Avatar
Did the same thing acouple of weeks ago. Definite improvement; but still not as bright as I would like.
Old Nov 29, 2004 | 07:10 PM
coobie's Avatar
I agree I think they are a pain in the A$$ to change.I bought the PIAA bulbs for my truck.I hope they last for a long time.coobie
Old Nov 29, 2004 | 07:16 PM
cquestad's Avatar
Install The Brite Box and adjust the height of the light pattern. I have never had better lighting than my set up now...with the STOCK bulbs.
Old Nov 29, 2004 | 07:18 PM
coobie's Avatar
Do they have the brite box for the 2004 trucks now ?? coobie
Old Nov 29, 2004 | 07:20 PM
coobie's Avatar
I see your truck is a 2004,where did you get the brite box from,thanks for any info.coobie
Old Nov 29, 2004 | 07:31 PM
cquestad's Avatar
If it is not released yet...it will be soon. I was a beta tester.
http://www.thebritebox.com
Old Nov 29, 2004 | 07:33 PM
coobie's Avatar
Thanks for the Info.coobie
Old Nov 29, 2004 | 08:25 PM
Jmac's Avatar
Also on Genosgarage.com
Old Nov 30, 2004 | 06:42 AM
roadrat's Avatar
Genos has them, but with the 3rd gen trucks you need two, one for each headlight, $149.95 for the pair.
rob
Old Nov 30, 2004 | 09:54 AM
Lightman's Avatar
I just don't see how anyone thought changing the headlight bulbs was a pain. It couldn' t have been easier, it took me at most 10 minutes to do both sides. Three torx bolts and the entire headlight assembly pops out forward, change the bulb, reverse... what was so tricky?
Old Nov 30, 2004 | 10:02 AM
coobie's Avatar
Lightman,I should have added,I have a full brush guard on my truck.I had to buy a longer Torx srew driver to get to the outside screw.coobie
Old Nov 30, 2004 | 10:29 AM
Lightman's Avatar
Sounds like that could get in the way coob
Old Nov 30, 2004 | 11:39 AM
coobie's Avatar
Yes it can,I had to take the brush guard all the way off the truck.Kind of pain in the rear.But I still grin every time I drive this truck.Take care,coobie
Old Nov 30, 2004 | 02:12 PM
Jmac's Avatar
I didn't know the headlight assembly came out!! I need a service manual!!
Jamie
