Install level kit..
Old Oct 6, 2007 | 12:51 PM
gscmiller's Avatar
Talking Install level kit..
I just ordered my 2" level kit from top gunz (dealt with cody, really a nice guy to do business with). Any one have the steps to install these? Any speical tools/ skill requried.
Old Oct 6, 2007 | 04:42 PM
LFD2037's Avatar
X2. Bump!!!
Old Oct 6, 2007 | 07:37 PM
Luvnacumns's Avatar
Yes.... A spring compressor and your life will be easy... It took me about 45 minutes to do each side with the spring compresor... Other than that it is really simple unbolt the shocks and shock towers and put the spacer in and bolt it back up.. Passenger side is pretty easy driver's side is a little more complicated with some junk in the way but takes about 15 minutes more or so....
Also jack the truck up and put mounts under the frame and let the front end hang if possible...
Shane
Old Oct 6, 2007 | 07:57 PM
LFD2037's Avatar
Unhook the track bar & anti-sway bar or leave them hooked up during install?
Old Oct 6, 2007 | 08:01 PM
01smoker's Avatar
That is the same kit I have on my truck. It will come with directions on how to do it. Yes be sure and unhook your track bar and sway bar.
Old Oct 6, 2007 | 08:26 PM
wngnt954's Avatar
You don't need a spring compressor. Just get the truck high enough to drop the axle all the way down to till the link bars stop it. The spacer and spring will go right in. Should take about an hour.
Old Oct 6, 2007 | 08:39 PM
Luvnacumns's Avatar
Un hook it...
Tried that and it still wouldn't work that's when I got the spring compressor it was a free rental from an auto parts store so it made life soooo much easier...
JJCAMARO1952000
Jul 4, 2011 08:24 AM
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
