Injector size question......
I am planning to get a HTT ss62/13/65 turbo that will be used alone for now but will soon be the small turbo in a twin setup with a S400 on bottom. I have a Floor-it stage II pump and was going to get a set of DonM Flux 2 (or 1.8) injectors. I want a REALLY CLEAN running truck with little or no black smoke. Will this be possible with the Flux 2's? Or should I go a little smaller with the 1.8's? I would consider going bigger but I don't want to affect mileage and I will be happy with around 500-550 hp. I assume this combo would get me there, and I want to use the smaller 65 wheel in the top turbo to help with spool up, I hate lag.
I am interested in this too. I am looking at twins also, maybe the ATS 3000/5000 set. I was thinking conservatively. Would flux 1.5s with a smarty be enough for clean power or would 1.8s or 2.0s be better choices.
I have flux 1's and they will smoke hard if you try.They have a haze even under light excelleration,but clear up when you level out.Its all how you drive it is my point.I would get the flux2's if I had it to do over again.
schoust
Oct 21, 2009 10:09 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
oscaroc
Apr 2, 2005 12:14 PM
