Injector Question Re: Noise/Driveability
Old Nov 27, 2006 | 07:14 PM
masonic-dodge's Avatar
If you spray the NO2 before the intercooler and the Meth in the intake you will be OK
CRIS
Old Dec 17, 2006 | 11:03 PM
BlackBeast's Avatar
How big of Injectors can you run on an 06 common rail and still daily drive it.
Old Dec 17, 2006 | 11:04 PM
BlackBeast's Avatar
06 common rail manual that is
Old Dec 18, 2006 | 12:59 AM
D.Wiggs's Avatar
I am running Flux 3+ so as big as you want if you have the supporting mods.
Old Dec 18, 2006 | 01:50 AM
BlackBeast's Avatar
Can I put 200 hp injectors on my 06 and drive it everyday with dual cp3/crazy lary/edge hot juice/fass150/and if possible 200hp sticks for fuel. those are some pretty good fuel mods pluse a very long list of goodies I have everything you have being put together except cams,fire ringed i heard cam is useless upgrade for common rail.
Old Dec 18, 2006 | 02:24 AM
chw's Avatar
chw
the helix cams make a big diff on 04.5-up common rails or so ive heard from Don and others.
Old Dec 18, 2006 | 03:07 AM
D.Wiggs's Avatar
Yes, a cam is a HUGE upgrade as far as drivability, power, and acceleration.
Old Dec 18, 2006 | 03:34 PM
BlackBeast's Avatar
Ok the guys at DDP told me save my money because on an 06 a cam is not gonna do much. I just want 700rwhp on #2 ONLY and I think My truck will be able to do it with everything I got.
Old Dec 18, 2006 | 06:42 PM
D.Wiggs's Avatar
You really should get a cam. I am upgrading my cam from the ATS to the Helix 2.
Old Dec 18, 2006 | 07:47 PM
judge88's Avatar
i originally had flux 1's now i have flux'3s. no white smoke at al. idle as smooth if not smoother than stockers. when i sent my 1's in to get upgraded to 3's don had to fix an injector . i would say pressure killed yours. you can bet when don sends the injectors out there 100% perfect.
Old Dec 18, 2006 | 11:14 PM
D.Wiggs's Avatar
Yes the MP-8 actually destroyed 3 of my injectors. Now it runs great!
Old Dec 19, 2006 | 03:01 AM
BlackBeast's Avatar
help
Hey D.WiGGS your truck is awesome My truck is an 06 dually and they are a lot a like except you did twins and rings and I did not do those. I am going to have my injectors ordered when I can make up my mind. What size do you have and what size do you think you need to make 750rwhp with my setup. I still want to drive my truck everyday. Right now Im telling my mechanic 150hp but I think I should go bigger advise please.
Old Dec 19, 2006 | 04:15 PM
D.Wiggs's Avatar
Don made me a set of Flux 3.3s. I will go bigger whne I increase my air and fuel supply (after the New Year) Can you fill out yoru signature so I have a better idea? I would, assuming all your mods are there to support it, go with the Flux 3's and do the Helix 2 Cam. I believe that those are your best bet. Then I would do either a dual CP3 setup, or at least the Stage 2 CP3 from Floor-It. That setup is awesome!
Old Dec 19, 2006 | 04:25 PM
dodgezilla04's Avatar
what are you going to do now to increase air, run triples?
Old Dec 19, 2006 | 04:48 PM
RyeThomas's Avatar
Winner winner chicken dinner!
With D.WIGGS it wouldnt suprise me, its always fun to see what he has up his sleeve next.
