Injector Quality
Old Sep 27, 2013 | 03:03 PM
soulezoo's Avatar
DTR 1st Sergeant
To the OP, that low rpm rattle you have is common with larger injectors. It is not a quality issue.
Folks have been trying to tune that rattle out forever now.
Old Sep 27, 2013 | 08:00 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Originally Posted by Spooler
I've been on here long enough to know the deal.....
Yeah I get pretty wound up when a guy tries to blame his wife for his mistakes and to cover his lies.........So easy to simply say Oops I forgot...no need to try and make the wife look like a fool....to me that is No man at all.
Old Sep 27, 2013 | 11:23 PM
EdmontonCanada's Avatar
Yeah, I've heard that. It's a tough thing...I'll assume they're ok. EGTs are normal and fuel milage is unchanged. The rattle seems to be more prevalent when the engine is up to temp.
Old Sep 28, 2013 | 05:18 AM
RyeThomas's Avatar
Winner winner chicken dinner!
Have you run your idle balance rates with EFI Live? If so do you remember the numbers? Its a good tool to help keep an eye on things.
Old Sep 29, 2013 | 08:39 PM
You're too smart for me Rye...explain what that's all about...
Old Sep 30, 2013 | 05:45 AM
RyeThomas's Avatar
No that's not the case at all!
Ok let's start with have you logged and read anything with EFI?
If yes this will be easy, if no I can walk you through it.
Bottom line is you log the truck after it is warm at idle, just let it run a min or so while recording data. Then you open that log file and select the injector balance rates 1-6 in a Dashpage. Then you watch them, most will say anything above +- 3.0 and its time for some concern and anything +- 4.0 is a must to at the least pull and have tested/replace ASAP.
The balance rate is a great tool to give you an idea what's going on. The ECM at idle has the ability to add or remove fuel from each injector in order to achieve a good quality idle. When the Numbers get between 3-4 the injectors are not balancing well, which gives you a good indication something is up and its time to take a better look.
All of the above is in Layman's terms, so you gurus don't beat me up. If you don't have any clue how to log and read files look up my EFI thread. It has links to very detailed DIY instructions courtesy of Rich at DogHouse Diesel. The guy spent a ton of time doing these for free and is a wealth of knowledge.
Any questions let me know and I'll try my best to help, Rye.
Old Sep 30, 2013 | 12:14 PM
Although my truck is programmed with EFI live, I don't have the device. The gentleman that programmed my truck said that it's his understanding this feature is only available for duramax...
Old Sep 30, 2013 | 01:41 PM
RyeThomas's Avatar
I can assure you it works on our trucks, I track mine monthly and keep a log.
Old Oct 14, 2013 | 01:35 PM
tom creek's Avatar
F1 is hands down the best.
Yes they do great work and are good people.but not the best for commonrails.Schied or Exergy for the commonrail your talking to someone who knows by experience x 4
Old Oct 23, 2013 | 10:37 PM
How so?
Old Oct 24, 2013 | 07:51 PM
tom creek's Avatar
Originally Posted by EdmontonCanada
How so?
First thing is when you install them you dont want to run down the bad ones pull them again wait another ten days to get them back. The equipment to test them is expensive a lot of builders dont have the stuff to build them right the first time.From time to time even the best send a bad one.It realy boils down to how many times you want to pull them and then put them back. Its a pain and not to mention the down time without your truck. Mine was down for almost two months sending them back and forth then you get,well you must have installed them wrong i could go on and on but when i went with the Schied injectors the truck ran better than it ever has with 0 problems.Shimming flow rates spray angle and all that goes with it you might want to ask someone else. All i know is what works the first time.Your time and money is worth as much as theirs who ever you buy from.Thats how so as best i can tell ya
Old Oct 26, 2013 | 06:47 AM
railroaderone's Avatar
Check out my thread in installed new injectors won't start I ended up changing the injectors one at a time to get it right. Took eight of them to get six good ones.
Old Oct 26, 2013 | 09:09 PM
Thanks, good info!
Old Oct 27, 2013 | 05:28 AM
Onat Dts's Avatar
thanks, very useful info.
Old Oct 27, 2013 | 04:25 PM
Blueboy's Avatar
Pretty flaky individual...the guy flat out lied to me repeatedly including the old "Check is in the mail" dodge to even trying to blame his lies on his wife...
I wouldn't trust him to carry a pail of water 3 feet...
I agree with Larry. I bought a 7000 mile used pump because
Shane came on line and vouched for person selling pump, told
me guy was a honest person. When I received pump didn't look
like 7000 mile pump. Paid $1100 + good pump. Called Shane
and asked if he would check pump for me, would not return calls.
Put pump on went 100 feet soft plugs blew. I caught Shane on
another forum and called him out. He told me that's what I get
for buying a used pump.
