industrial injection super 62/14
Old Aug 15, 2006 | 10:55 PM
dodgezilla04's Avatar
the new turbo just arrived yesterday. I will have to wait till saturday to install. A quick look tells me that the pacbrake bracket will need to be clearance for the compressor outlet pipe to fit.
Anyone running a setup close to mine with any power numbers?
any install tips that will save me knuckle skin and learning new curse words?
Old Aug 16, 2006 | 06:43 AM
CATCRACKER2's Avatar
yea bolt on oil drain tube before bolting up turbo
Old Aug 16, 2006 | 09:34 AM
nriver's Avatar
are you going to make it to the NWD or NWB event this weekend? Just across the sound from you I think.
I may get up there
congrats on the new turbo, whats happening to the old? why the upgrade? what are your expected gains?
thanks
Old Aug 16, 2006 | 10:31 AM
staarma's Avatar
I don't have any info for you but that is the same turbo I have my mind set on. I too am a little concerned for the PACbrake cylinder bracket clearance. I look forward to your update on that as well as the install and the function. Thanks.
Old Aug 16, 2006 | 12:25 PM
twest's Avatar
You will need to strave off 1/4" of the Pac Bracket,Also with the additional weight of the Pac some stud"s have broken off,No problem though We drill the studs out in put Automotive Bolts in,I like the Bolts,You can switch out Turbo"s twice as fast.
Old Aug 16, 2006 | 01:47 PM
putting on the turbo to lower towing egt's, and give me some more ooomph.
cant make it to nwb, gotta put on the turbo and do some yardwork. yes just across the sound.
figured out the drain tube already, thanks for the heads up. i will take some pics as I do it. hoping to set it at 50 psi. then i should be ok without studs.
Old Aug 16, 2006 | 01:49 PM
the old will just sit in a box i suppose. nothing wrong with it, just pushed beyond its efficiency and i dont feel like taking my chances on it grenading at 44psi.
Old Aug 16, 2006 | 03:31 PM
staarma's Avatar
Awesome, looking forward to your progress.
Old Aug 16, 2006 | 04:39 PM
wap's Avatar
wap
I dont mean to steal this thread but I am about to do a turbo swap myself (and it will likely be the exact same one) and I was wondering if there was any way to get the turbo bolts off the manifold besides an open end.
I tried to get my turbo off to drill for my pyro and all I could do was spread the end of the wrench open and I quit before I rounded the bolts.
Is there a better way?
Am I doin somethin wrong?
Let us know how you like the turbo, I am very interested as I am sure many others are.
Old Aug 16, 2006 | 04:51 PM
soak the fasteners with kroil while still warm a few days before you try to take them off. mine are 2 years old and show no signs of rust. however, i will find out saturday morning.
Old Sep 22, 2006 | 08:35 PM
Syndicate's Avatar
well how do you like the new turbo? What is the spool like? How about the temps?
Old Sep 22, 2006 | 09:51 PM
morkable's Avatar
you will love that turbo, I pulled my big a** 5th wheel through the mountains for 9 days,, never went over 1320,, and spools real nice,,Im very glad I went with it
Kevin
Old Sep 22, 2006 | 10:04 PM
i love this thing. the money was very well spent. my tt weighs about 10k, egts never went over 1200*, no matter how long of a hill i was pulling. with the quad on 60, i can tow anywhere. with the race box maxed out, the clutch slips as soon as boost builds past 20. you should hear this thing at 50psi. if you tow and have a downloader or chip and have egt trouble, get a II SPS 62/14. you will not be sorry.
Old Sep 25, 2006 | 09:58 PM
oh I am enjoying it so much, I killed my factory clutch.
try using a smarty with that turbo, got rid of any lag. spools that baby now.
4969joes
Feb 22, 2010 01:22 PM
PourinDiesel
23
Jul 15, 2005 08:25 PM
OT-OF-Here
18
May 23, 2005 12:18 PM
bhaner
May 11, 2005 11:27 AM
sleds
Jan 13, 2005 06:23 AM
