II stage 3 cp3
Old Jul 10, 2007 | 12:55 AM
Jethro6213's Avatar
II stage 3 cp3
Is anyone on here running the stage 3 cp3 for Industrial Injection? I think it is a modded Duramax cp3. Just wanting to hear what you guys think of it.
Old Jul 10, 2007 | 07:30 AM
jrussell's Avatar
Might want to do a seach for this topic. There were some recent reports from unhappy II customers whose modded CP3's weren't able to keep up.
Old Jul 10, 2007 | 09:11 AM
king d's Avatar
i ran ii cp3 stage 2 and have had good results,it does have a bit of noise to it but gives more fuel than the stock one by far,recently with with a twin set up and now run dual ii stage 2 pumps...
Old Jul 10, 2007 | 09:35 AM
973604x4's Avatar
its a modded d-max pump. Don't waste your time.
Old Jul 10, 2007 | 10:26 AM
morkable's Avatar
The stage 2 IIS pump is NOT a modded duramax pump. If it was it wouldnt fit on your engine. I have one and so far it is good. I am starting to get to the point now where I need more fuel than what it can provide, so I am looking at dual cp3's, but I am going to keep using this pump in my dual setup.
Oh and for some FYI, it is too bad we couldnt put a duramax pump on our trucks, as they flow better than our units ( a stock duramax dosent use or require a lift pump)
Kevin
Old Jul 10, 2007 | 10:30 AM
973604x4's Avatar
theres a truck in Texas with a stage 3 cp3 from II....and its a d-max pump
Old Jul 10, 2007 | 10:33 AM
morkable's Avatar
In a dual setup, they will use a dmax pump on the top, mostly due to that it is a little more compact. But trust me a dmax pump wont bolt up on to the stock location
Kevin
Old Jul 10, 2007 | 10:46 AM
Jethro6213's Avatar
I talked to II Friday and they told me that the stage 3(43% over stock) pump was a modded Duramax pump. I don't know, I'm just going by what they told me.
Old Jul 10, 2007 | 11:04 AM
morkable's Avatar
Hmmm,, weird,, I wonder how they do that,, I have the stage 2 and it is definately the dodge unit..... it makes sense to do the duramax pump,,,, but I just dont quite get how it would bolt up,, unless I am missing something that I am just blind too.... Oh well they would know, they are the ones building it
Kevin
Old Jul 10, 2007 | 11:10 AM
Jethro6213's Avatar
I think the fuel line has to be changed or something.
Jethro6213
19
Jul 11, 2008 11:59 AM
Doubleover
Apr 21, 2006 02:38 AM
052500#1
13
Jan 6, 2006 03:27 PM
timb
Aug 19, 2005 10:16 PM
