II Silver 62 / S480
Old Jan 24, 2009 | 01:06 AM
desertchecker's Avatar
II Silver 62 / S480
anyone tried this combo in a twin set ?
Old Jan 24, 2009 | 09:41 AM
Diesel- Dummy's Avatar
I love mine set up .I been towing 10,000 lbs weekly and thay have been good for 11.85 et at 113mph with my little so vp pump Id say on a CR truck thay would even work better good luck
Old Jan 24, 2009 | 03:22 PM
thanks for the feed back
by the looks of your sig u have the htt 62/65/13ss ?
thats a much different turbo then the II Silver 62/74/14cm
did you change your top turbo recently & switch from the htt to II Silver ?
with all the guy's now running twins on this forum Im very surprised that no one has any experience with a silver series in a twin set ?
Old Jan 24, 2009 | 09:50 PM
nrussell's Avatar
i have the silv62/s400 and could'nt be happier
Old Jan 24, 2009 | 11:03 PM
mudder500's Avatar
I got silverbullet-480 combo
Old Jan 25, 2009 | 12:20 AM
Wow ..... thats cool.....
I bet when that silver starts to build boost , truck gets moving quick !
How does it spool on the street & what rpm do guys start to spool up & build boost ?
What do the egt temps look like , just cruising , towing & at WOT ?
Old Jan 25, 2009 | 11:06 AM
I went from the silver 62 to my htt62 ss13 I think it was a day and night diff, the ss13 spool up was way better plus the wastgateing inside has two times the flow that the II 62 had . Why would you wont a big slow EX wheel (74) ? in a twin set you'll have all the air you need for 850 hp with the s480 and low drive pressure with the big internal Htt ss13 wastgate . IF you dont use a ss13 you should get a bigger EX wheel ie the 74 in a cast iron back housing so you drive pressure will stay low . One more thing the heat retention in the ss13 will light the s480 better (sooner) than a cast housing will . Worked on my truck and a buddys truck also . Good luck with your setup
Old Jan 27, 2009 | 12:47 PM
thanks you all.... for the feed back !
homewrecker
Jul 11, 2008 02:54 PM
homewrecker
14
Jul 1, 2008 10:48 AM
mykal41
23
Jun 6, 2008 12:42 AM
nrussell
22
Apr 23, 2008 02:50 PM
PowerDually
Jun 30, 2007 05:31 PM
