I need to clear p 0148 code
Old Sep 22, 2007 | 03:54 PM
rodsram's Avatar
Did a test run with Xillarader and got the fuel delivery error code, need to clear it.
Will any of the parts stores be able to do this for me?
I just added the fuel and rail pressure guage, it seems the Xillarader easily pulls down to 1psi.
Runns great, just need to clear that code.
Thanks
Old Sep 22, 2007 | 03:58 PM
qzilla's Avatar
It will go away on its own as long as you do not keep pulling the pressure down to nothing.
A few keystarts, maybe this evening, maybe tomorrow. It will go away.
Old Sep 22, 2007 | 04:33 PM
rodsram's Avatar
Thanks qzilla,
I went to Autozone, they have the OB II, it was able to read the code, but not erase it.
As`you said, I need to key start a few times as if I were attempting to read the codes every now and again, and TRY, to keep my foot off the Skinny peddle, and this will go away?
I hope so - as Local dealer does not enjoy my mods.
Thanks again, will keep you posted.
Old Sep 22, 2007 | 05:24 PM
qzilla's Avatar
It will go away. You can still play with it but, if you know you are pulling the fuel pressure way down then don't run it quite that hard. That is what causes the 0148 code to start with.
Next step is to get some sort of pusher pump and the 0148 will be forever gone!
Old Sep 22, 2007 | 06:56 PM
rodsram's Avatar
Pusher pump.
mmm..
I feel the research bug again, it always seems it is directly related to the wallet.
Thanks again
DCDOC
Aug 9, 2009 12:46 PM
Floridacracker
Oct 12, 2008 11:02 AM
Crobinson
GADTR #40
Sep 24, 2008 06:12 PM
iweb
Apr 30, 2008 08:31 AM
screamin01
Jan 22, 2008 05:48 PM
