HTT 71 stainless or Silver 62?
It's not over time. I would call them back and let them know you are aware of some issues and make sure what they send you is checked and re-checked. They already told my dad if he takes it apart to look at it to check and see if it's seating, that they will void his warranty.
Andy
I started with an HTB2 62/12 then progressed to the 62/71/13 ss. I can't tell the difference in spooling off of the bottom. They both feel like stock. The noticeable difference to me is the mid range from about 20-40 PSI. That area noticably pulls harder although I only have dyno figures for the HTB2. I will dyno the HTT once I get my new muffler on. Everything else is done and ready to go. The other thing is that my cruising EGT's are up about 100 degrees and the boost is non existent when cruising. So at 65 MPH I see maybe 0-2 PSI. Cruising 80 MPH I will see 6-8 PSI. But, if I drop the hammer it spools to 15 instantly and then it lites and takes off.
I got the turbo and installed it this past weekend. I can only manage to get about 32psi out of it with everything cranked up but while it peaks around 30psi the lift pump pressure is sitting at zero so that probably has something to do with it.
It makes a squeal kind of a sound as the boost starts to build up past about 13psi on top of the regular turbo whine and pinching off the wastegate line didn't change anything. Is this similar to your problem omaharam? How do you know there is a leak? I am going to have to yank my intercooler to see if there is a leak on it, too.
Other than this (maybe it's not a problem at all) it runs like a raped ape now.
Andy
Andy
Htt
HTT has been really good to deal with and MPI is outstanding. You get what you pay for!!
my silver 62 spooled fast and pulled hard i had to swap it out for a bullet though wanted more power so now im running the bullet and using it in a twin set up soon
Andy
Andy
Andy
