Htt 62/71/14
Old Sep 22, 2011 | 10:25 AM
mrploww's Avatar
Htt 62/71/14
I am looking at buying a used HTT H2B2 turbo for my 03 6 speed. I tow 10,000lbs about 3-4 times per year with one of those times going from OH to central PA through some mountains. Will this turbo be too laggy for towing? I called HTT and they told me that is not a good towing turbo, but i notice several people on here that have the turbo.
I would like to do some 50 horse injectors at some point and maybe that would help the turbo.
Thanks for the advice!
Old Sep 22, 2011 | 10:46 AM
soulezoo's Avatar
DTR 1st Sergeant
That really isn't the best turbo for towing due to the 14cm exhaust housing. But it is still a decent turbo. Having a manual will allow you to drive around the lag though by keeping RPMs up.
If you can swap to the 12cm exhaust housing, that would be the best setup for you and then you would have a good turbo for your purposes.
Old Sep 22, 2011 | 12:02 PM
jeephauler's Avatar
Sounds similar to how I am using mine. I dont have any problems, I simply keep the RPMs above 2k when pulling hills and it works well.
O.T
16
Jan 14, 2008 02:47 PM
Bobcat698
Nov 8, 2006 11:20 AM
Monty
Dec 24, 2004 11:50 AM
bwat4
Dec 15, 2004 05:08 PM
Chris Rowe
Dec 31, 2003 08:47 AM
